Introduction
A pretty good video tutorial can be found here:
In addition, a illustrated guide follows below.
Video Overview
First, loosen the two screws on the left and right of the USB port (P2 bit).
Carefully pry the smartphone cover upward bit by bit, starting from the USB side.
Caution: Especially if the display is damaged in the corner, two gaps are visible (red arrows). You should use the lower one, as otherwise you’ll pry out the display and won’t be able to proceed further.
After opening, the smartphone looks like the first image. Now, the ribbon cable for the fingerprint sensor needs to be disconnected to separate the two halves.
You can either disconnect it on the cover side (second image) by lifting the gray plastic piece with a small screwdriver, or remove it on the "circuit board side" if you’re already planning to replace the battery or display (next step).
A brief overview of the function of each ribbon cable
Display (red)
Fingerprint sensor (blue)
Battery (green)
Connection to lower modules (yellow). Caution: The cable must be reinserted in the correct orientation during reassembly if it is disconnected at both ends.
Coaxial cable (also yellow, obscured) to the lower module.
To disconnect the cables, remove the Phillips screws and pry out the cover plates. At the points marked with an arrow, the plates are additionally clamped beyond the screws.
Follow the steps in reverse order to reassemble your device.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
