Up to 20% off select tools
Huawei Honor 6x Front Camera Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
90
All Time:
1,885
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the front camera on your device is failing or blurry you may need to replace the assembly. This guide will follow you through the steps required to open your device to get to the front camera.
    1. Huawei Honor 6x Front Camera  Replacement, SIM Card: step 1, image 1 of 1
      • Turn off the device.
      Ask FixBot
    2. Huawei Honor 6x Front Camera  Replacement: step 2, image 1 of 2 Huawei Honor 6x Front Camera  Replacement: step 2, image 2 of 2
      • Insert the SIM Card Eject Tool into the SIM card tray hole.
      • Press the eject tool into the hole until the tray clicks open.
      Ask FixBot
    3. Huawei Honor 6x Front Camera  Replacement: step 3, image 1 of 1
      • Remove the SIM tray from the device using two fingers.
      • When reinserting the SIM card, be sure it is properly aligned with the SIM tray.
      Ask FixBot
    4. Huawei Honor 6x Front Camera  Replacement: step 4, image 1 of 1
      • Remove the SIM card from the compartment using two fingers.
      Ask FixBot
    1. Huawei Honor 6x Front Camera  Replacement, Back Cover: step 5, image 1 of 2 Huawei Honor 6x Front Camera  Replacement, Back Cover: step 5, image 2 of 2
      • Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
      • Pry the screen off the back of the phone by pushing down on the opening tool.
      Ask FixBot
    2. Huawei Honor 6x Front Camera  Replacement: step 6, image 1 of 3 Huawei Honor 6x Front Camera  Replacement: step 6, image 2 of 3 Huawei Honor 6x Front Camera  Replacement: step 6, image 3 of 3
      • Slide the opening tool or spudger along the bottom of the phone and around the edge.
      Ask FixBot
    3. Huawei Honor 6x Front Camera  Replacement: step 7, image 1 of 2 Huawei Honor 6x Front Camera  Replacement: step 7, image 2 of 2
      • Once three sides of the screen are detached, pry the phone apart using two hands.
      • When separating the back panel from the screen, do not pull them too far apart. There is an interconnect that is attached to both sides that could break, or tear, if pulled too far.
      Ask FixBot
    4. Huawei Honor 6x Front Camera  Replacement: step 8, image 1 of 3 Huawei Honor 6x Front Camera  Replacement: step 8, image 2 of 3 Huawei Honor 6x Front Camera  Replacement: step 8, image 3 of 3
      • Remove the five 4mm Phillips #00 screws using a screwdriver.
      Ask FixBot
    5. Huawei Honor 6x Front Camera  Replacement: step 9, image 1 of 1
      • Remove the motherboard cover from the device using a spudger or your fingers.
      Ask FixBot
    1. Huawei Honor 6x Front Camera  Replacement, Front Camera: step 10, image 1 of 3 Huawei Honor 6x Front Camera  Replacement, Front Camera: step 10, image 2 of 3 Huawei Honor 6x Front Camera  Replacement, Front Camera: step 10, image 3 of 3
      • Pry the seven connectors off using a spudger or your finger.
      Ask FixBot
    2. Huawei Honor 6x Front Camera  Replacement: step 11, image 1 of 3 Huawei Honor 6x Front Camera  Replacement: step 11, image 2 of 3 Huawei Honor 6x Front Camera  Replacement: step 11, image 3 of 3
      • Remove the four 2 mm Phillips #00 screws.
      Ask FixBot
    3. Huawei Honor 6x Front Camera  Replacement: step 12, image 1 of 2 Huawei Honor 6x Front Camera  Replacement: step 12, image 2 of 2
      • Lift the motherboard off of the phone using a spudger or two fingers.
      • The left side of the motherboard has a strip of rubber that may need some prodding from a spudger to remove.
      Ask FixBot
    4. Huawei Honor 6x Front Camera  Replacement: step 13, image 1 of 2 Huawei Honor 6x Front Camera  Replacement: step 13, image 2 of 2
      • Remove the cable connecting the camera from the motherboard using a spudger or your finger.
      Ask FixBot
    5. Huawei Honor 6x Front Camera  Replacement: step 14, image 1 of 3 Huawei Honor 6x Front Camera  Replacement: step 14, image 2 of 3 Huawei Honor 6x Front Camera  Replacement: step 14, image 3 of 3
      • Remove the front camera out from the motherboard by pushing on it with the tip of a spudger.
      • This is best done from the back side of the motherboard and pushing where the cable meets the camera.
      Ask FixBot
2 other people completed this guide.
Author
with
Tessa Kemper
609 Reputation
3 Guides authored
Cal Poly, Team S13-G5, White Fall 2018 Member of Cal Poly, Team S13-G5, White Fall 2018
CPSU-WHITE-F18S13G5
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 90
All Time: 1,885
