Huawei Honor 6x Fingerprint Scanner Replacement
    1. Huawei Honor 6x Fingerprint Scanner Replacement, SIM Card: step 1, image 1 of 1
      • Turn off the device.
      Ask FixBot
    2. Huawei Honor 6x Fingerprint Scanner Replacement: step 2, image 1 of 2 Huawei Honor 6x Fingerprint Scanner Replacement: step 2, image 2 of 2
      • Insert the SIM Card Eject Tool into the SIM card tray hole.
      • Press the eject tool into the hole until the tray clicks open.
      Ask FixBot
    3. Huawei Honor 6x Fingerprint Scanner Replacement: step 3, image 1 of 1
      • Remove the SIM tray from the device using two fingers.
      • When reinserting the SIM card, be sure it is properly aligned with the SIM tray.
      Ask FixBot
    4. Huawei Honor 6x Fingerprint Scanner Replacement: step 4, image 1 of 1
      • Remove the SIM card from the compartment using two fingers.
      Ask FixBot
    1. Huawei Honor 6x Fingerprint Scanner Replacement, Back Cover: step 5, image 1 of 2 Huawei Honor 6x Fingerprint Scanner Replacement, Back Cover: step 5, image 2 of 2
      • Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
      • Pry the screen off the back of the phone by pushing down on the opening tool.
      Ask FixBot
    2. Huawei Honor 6x Fingerprint Scanner Replacement: step 6, image 1 of 3 Huawei Honor 6x Fingerprint Scanner Replacement: step 6, image 2 of 3 Huawei Honor 6x Fingerprint Scanner Replacement: step 6, image 3 of 3
      • Slide the opening tool or spudger along the bottom of the phone and around the edge.
      Ask FixBot
    3. Huawei Honor 6x Fingerprint Scanner Replacement: step 7, image 1 of 2 Huawei Honor 6x Fingerprint Scanner Replacement: step 7, image 2 of 2
      • Once three sides of the screen are detached, pry the phone apart using two hands.
      • When separating the back panel from the screen, do not pull them too far apart. There is an interconnect that is attached to both sides that could break, or tear, if pulled too far.
      Ask FixBot
    4. Huawei Honor 6x Fingerprint Scanner Replacement: step 8, image 1 of 3 Huawei Honor 6x Fingerprint Scanner Replacement: step 8, image 2 of 3 Huawei Honor 6x Fingerprint Scanner Replacement: step 8, image 3 of 3
      • Remove the five 4mm Phillips #00 screws using a screwdriver.
      Ask FixBot
    5. Huawei Honor 6x Fingerprint Scanner Replacement: step 9, image 1 of 1
      • Remove the motherboard cover from the device using a spudger or your fingers.
      Ask FixBot
    1. Huawei Honor 6x Fingerprint Scanner Replacement, Fingerprint Scanner: step 10, image 1 of 2 Huawei Honor 6x Fingerprint Scanner Replacement, Fingerprint Scanner: step 10, image 2 of 2
      • Disconnect the fingerprint scanner cable attached to the motherboard using a spudger or your finger.
      Ask FixBot
    2. Huawei Honor 6x Fingerprint Scanner Replacement: step 11, image 1 of 1
      • Apply heat around the finger print scanner assembly using a heat gun or hair dryer.
      Ask FixBot
    3. Huawei Honor 6x Fingerprint Scanner Replacement: step 12, image 1 of 1
      • Separate the fingerprint scanner assembly from the back panel using a spudger.
      • This step can be difficult. You may consider using a metal spudger.
      • Be careful not to damage the black rubber adhesive around the fingerprint scanner. It is needed for water and dust resistance.
      Ask FixBot
    4. Huawei Honor 6x Fingerprint Scanner Replacement: step 13, image 1 of 1
      • Remove the finger print scanner from the device by lifting it with two fingers.
      • When reattaching the fingerprint scanner assembly, additional adhesive may be required.
      Ask FixBot
5 other people completed this guide.
Tessa Kemper
609 Reputation
3 Guides authored
Cal Poly, Team S13-G5, White Fall 2018 Member of Cal Poly, Team S13-G5, White Fall 2018
CPSU-WHITE-F18S13G5
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 46
All Time: 1,879
