Huawei Honor 5X Volume and Power Buttons Replacement
    1. Huawei Honor 5X Volume and Power Buttons Replacement, HUAWEI HONOR 5X Disassembly: step 1, image 1 of 1
      • Turn off your cell phone before disassembling.
      Ask FixBot
    2. Huawei Honor 5X Volume and Power Buttons Replacement: step 2, image 1 of 1
      • Remove the two 1.17mm Torx T3 screws from the bottom of the phone.
      Ask FixBot
    3. Huawei Honor 5X Volume and Power Buttons Replacement: step 3, image 1 of 2 Huawei Honor 5X Volume and Power Buttons Replacement: step 3, image 2 of 2
      • Use the Sim card ejection tool to remove both the sim card trays.
      Ask FixBot
    4. Huawei Honor 5X Volume and Power Buttons Replacement: step 4, image 1 of 1
      • To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
      Ask FixBot
    5. Huawei Honor 5X Volume and Power Buttons Replacement: step 5, image 1 of 2 Huawei Honor 5X Volume and Power Buttons Replacement: step 5, image 2 of 2
      • Pry off the back with a plastic opening tool.
      Ask FixBot
    1. Huawei Honor 5X Volume and Power Buttons Replacement, Battery: step 6, image 1 of 1
      • Remove the pink sticker.
      Ask FixBot
    2. Huawei Honor 5X Volume and Power Buttons Replacement: step 7, image 1 of 1
      • Remove the three 1.5mm Phillips #000 screws.
      Ask FixBot
    3. Huawei Honor 5X Volume and Power Buttons Replacement: step 8, image 1 of 2 Huawei Honor 5X Volume and Power Buttons Replacement: step 8, image 2 of 2
      • Use a plastic opening tool to disconnect the orange and black battery cables from the motherboard.
      Ask FixBot
    4. Huawei Honor 5X Volume and Power Buttons Replacement: step 9, image 1 of 1
      • Remove the battery from the phone.
      Ask FixBot
    1. Huawei Honor 5X Volume and Power Buttons Replacement, Motherboard: step 10, image 1 of 2 Huawei Honor 5X Volume and Power Buttons Replacement, Motherboard: step 10, image 2 of 2
      • Remove the five 1.5mm Phillips #000 screws from the motherboard.
      Ask FixBot
    2. Huawei Honor 5X Volume and Power Buttons Replacement: step 11, image 1 of 2 Huawei Honor 5X Volume and Power Buttons Replacement: step 11, image 2 of 2
      Tool used on this step:
      Buy
      • Use a plastic opening tool to pry up and disconnect the display cable from the motherboard.
      • Use tweezers to disconnect the white coax cable.
      • Use tweezers to disconnect the power and volume cable.
      Ask FixBot
    3. Huawei Honor 5X Volume and Power Buttons Replacement: step 12, image 1 of 3 Huawei Honor 5X Volume and Power Buttons Replacement: step 12, image 2 of 3 Huawei Honor 5X Volume and Power Buttons Replacement: step 12, image 3 of 3
      • Remove the motherboard.
      Ask FixBot
    1. Huawei Honor 5X Volume and Power Buttons Replacement, Volume and Power Buttons: step 13, image 1 of 2 Huawei Honor 5X Volume and Power Buttons Replacement, Volume and Power Buttons: step 13, image 2 of 2
      Buy
      • Use the tweezers to pull the button assembly from the small black clips on the back plate of the phone.
      Ask FixBot
Eric Petrous
145 Reputation
2 Guides authored
IUPUI, Team S1-G4, Hovde Fall 2019 Member of IUPUI, Team S1-G4, Hovde Fall 2019
IUPUI-HOVDE-F19S1G4
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 64
All Time: 1,740
