Huawei Honor 20 lite battery Replacement
    1. Huawei Honor 20 lite battery Replacement, heating back cover: step 1, image 1 of 1
      • Place phone on a heating bed.
      • I set it to 80 degrees celcius and left it on there for 5 minutes.
      Ask FixBot
    2. Huawei Honor 20 lite battery Replacement, removing the back cover: step 2, image 1 of 1
      • once the glue is softened, use the plastic pick tool to loosen one edge.
      • leave a pick under one side to stop that side from re-sticking as you move onto the next edge.
      Ask FixBot
    3. Huawei Honor 20 lite battery Replacement, undoing the screws: step 3, image 1 of 2 Huawei Honor 20 lite battery Replacement, undoing the screws: step 3, image 2 of 2
      • place the back cover side by side with the rest of he phone. being careful a the fingerprint scanner cable is on the back of the phone
      • take out all the screws in the bottom part of the phone and gently lift off, away from the phone.
      • unclip the ribbon cable.
      Ask FixBot
    4. Huawei Honor 20 lite battery Replacement, top screws: step 4, image 1 of 1
      • next repeat the same process along the top part. (be careful with the cameras, the cover should just unclip without much effort.)
      • be careful of the 2 screws circled. these need to come out as well.
      Ask FixBot
    5. Huawei Honor 20 lite battery Replacement, pulling battery tabs: step 5, image 1 of 2 Huawei Honor 20 lite battery Replacement, pulling battery tabs: step 5, image 2 of 2
      • gently pry the battery terminal away from the board
      • next pull tab 1 and 2 individually.
      Ask FixBot
    6. Huawei Honor 20 lite battery Replacement, battery removal: step 6, image 1 of 1
      • when you pull tab 3, the battery should hinge away from you and then pull towards you .
      Ask FixBot
      • insert a new battery and repeat the steps backwards.
      Ask FixBot
2 other people completed this guide.
chris dodds
172 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 54
All Time: 1,706
