Huawei Honor 10 Loudspeaker Unit Removal
  1. Huawei Honor 10 Loudspeaker Unit Removal, Rear Glass: step 1, image 1 of 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
    Ask FixBot
  2. Huawei Honor 10 Loudspeaker Unit Removal: step 2, image 1 of 3 Huawei Honor 10 Loudspeaker Unit Removal: step 2, image 2 of 3 Huawei Honor 10 Loudspeaker Unit Removal: step 2, image 3 of 3
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the back cover.
    • Lift the back cover's right edge with your suction cup, opening a slight gap between the back cover and the frame.
    • Insert the tip of an opening pick in the gap you created and slide it to the bottom right corner.
    Ask FixBot
  3. Huawei Honor 10 Loudspeaker Unit Removal: step 3, image 1 of 2 Huawei Honor 10 Loudspeaker Unit Removal: step 3, image 2 of 2
    • Apply more heat if the adhesive becomes hard to cut. During the removal process, the back cover is under tension all the time and is likely to break if the adhesive isn't softened enough.
    • Insert a second opening pick at the bottom right corner of the rear glass.
    • Slide the opening pick along the bottom edge of the rear glass to cut the adhesive and leave it in the bottom left corner.
    Ask FixBot
  4. Huawei Honor 10 Loudspeaker Unit Removal: step 4, image 1 of 3 Huawei Honor 10 Loudspeaker Unit Removal: step 4, image 2 of 3 Huawei Honor 10 Loudspeaker Unit Removal: step 4, image 3 of 3
    • Insert a third opening pick at the bottom left corner of the rear glass.
    • Slide the opening pick along the left edge of the rear glass to cut the adhesive.
    • Leave the opening pick at the top left corner of the rear glass.
    Ask FixBot
  5. Huawei Honor 10 Loudspeaker Unit Removal: step 5, image 1 of 2 Huawei Honor 10 Loudspeaker Unit Removal: step 5, image 2 of 2
    • Insert a fourth opening pick at the top left corner of the rear glass.
    • Slide the opening along the top edge of the rear glass and cut the remaining adhesive with it.
    Ask FixBot
  6. Huawei Honor 10 Loudspeaker Unit Removal: step 6, image 1 of 2 Huawei Honor 10 Loudspeaker Unit Removal: step 6, image 2 of 2
    • Carefully lift the rear glass of the Huawei Honor 10 and remove it.
    Ask FixBot
  7. Huawei Honor 10 Loudspeaker Unit Removal, Battery disconnect: step 7, image 1 of 3 Huawei Honor 10 Loudspeaker Unit Removal, Battery disconnect: step 7, image 2 of 3 Huawei Honor 10 Loudspeaker Unit Removal, Battery disconnect: step 7, image 3 of 3
    • Use a pair of tweezer to carefully peel the black foil off the loudspeaker and daughterboard cover.
    • Remove the foil completely.
    Ask FixBot
  8. Huawei Honor 10 Loudspeaker Unit Removal: step 8, image 1 of 1
    • Remove the three Phillips #00 screws (2.9 mm length) that secure the metal bracket on top of the battery, interconnect, and display flex cable.
    Ask FixBot
  9. Huawei Honor 10 Loudspeaker Unit Removal: step 9, image 1 of 2 Huawei Honor 10 Loudspeaker Unit Removal: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to remove the metal shield that covers the connectors of the interconnect cable, the battery and the display flex cable.
    Ask FixBot
  10. Huawei Honor 10 Loudspeaker Unit Removal: step 10, image 1 of 2 Huawei Honor 10 Loudspeaker Unit Removal: step 10, image 2 of 2
    • Use a spudger to pry up and disconnect the battery flex cable.
    Ask FixBot
  11. Huawei Honor 10 Loudspeaker Unit Removal, Loudspeaker Unit: step 11, image 1 of 1
    • Remove the seven Phillips screws securing the loudspeaker unit:
    • Three silver 2.9 mm long screws
    • Four black 3.4 mm long screws
    Ask FixBot
  12. Huawei Honor 10 Loudspeaker Unit Removal: step 12, image 1 of 3 Huawei Honor 10 Loudspeaker Unit Removal: step 12, image 2 of 3 Huawei Honor 10 Loudspeaker Unit Removal: step 12, image 3 of 3
    • There's a little bit of adhesive under the loudspeaker. It's possible to remove the loudspeaker without heating the adhesive but if you're having a hard time removing it, you can use an iOpener to soften the adhesive.
    • Slide the flat end of a spudger under the right side of the loudspeaker unit.
    • Pry up the loudspeaker unit until you can get a good grip.
    • Remove the loudspeaker unit.
    Ask FixBot
4 other people completed this guide.
Dominik Schnabelrauch
261,073 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
28,236 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 63
All Time: 4,730
