Huawei Ascend G700 SD Card Replacement
Views: 1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
32
Past 30 Days:
101
All Time:
1,012
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 55 seconds
Difficulty: Easy
Community-Contributed Guide
Parts
Tools
  • Spudger
    4.9
    1. Huawei Ascend G700 SD Card Replacement, Preparation: step 1, image 1 of 2 Huawei Ascend G700 SD Card Replacement, Preparation: step 1, image 2 of 2
      • Disconnect all connected devices (such as headphones and USB chargers).
      • Turn the device off.
      • Turn the device around.
      Ask FixBot
    2. Huawei Ascend G700 SD Card Replacement: step 2, image 1 of 1
      • On the same side as the powerbutton is a little notch. Using it you will have to carefully remove the back cover.
      • Use a small prying tool if you can't do this with your fingers.
      Ask FixBot
    3. Huawei Ascend G700 SD Card Replacement: step 3, image 1 of 2 Huawei Ascend G700 SD Card Replacement: step 3, image 2 of 2
      • Now you can remove the battery, that has to be pryed off in the marked location.
      Ask FixBot
    1. Huawei Ascend G700 SD Card Replacement, SD Card: step 4, image 1 of 3 Huawei Ascend G700 SD Card Replacement, SD Card: step 4, image 2 of 3 Huawei Ascend G700 SD Card Replacement, SD Card: step 4, image 3 of 3
      • You can now pull the SD card downwards.
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
Alex Niculescu is helping us fix the world! Want to contribute?
Start translating ›
Leonard Kesting
1,298 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 101
All Time: 1,012
