Up to 20% off select tools
Hp Zbook studio g3 RAM Replacement
Views: 5.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
97
All Time:
5,337
Comments: 6
3 comments on steps, 3 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Replacing the 8GB of ram in my HP zBook studio g3 mobile workstation to 16 GB
    1. Hp Zbook studio g3  RAM Replacement, Removing the dust filter: step 1, image 1 of 1
      • Remove the 4 screws holding down the dust filter
      • Remove the dust filter
      Ask FixBot
    2. Hp Zbook studio g3  RAM Replacement, Removing the housing: step 2, image 1 of 1
      • Remove the 4 outer screws.
      • Remove the 2 inner screws holding the housing down.
      • Now lift the housing. This may require some force
      Ask FixBot
    3. Hp Zbook studio g3  RAM Replacement, Removing the old Ram module: step 3, image 1 of 2 Hp Zbook studio g3  RAM Replacement, Removing the old Ram module: step 3, image 2 of 2
      • Remove the old ram module by pushing these two tabs outwards. The module should swing up
      • Now pull the module out away from the holder
      • Note: The removal of the module should not require a lot of force
      Ask FixBot
    4. Hp Zbook studio g3  RAM Replacement, Installing the new memory: step 4, image 1 of 1
      • Orient the memory modules such that then notch in the connector lines up with the grove in the module
      • slide the module all the way into the holder such that the pins are in the connector
      • Push down on the module to lock it in the holders
      • Note: Make sure the module is in straight
      Ask FixBot
3 other people completed this guide.
Author
with
jort
193 Reputation
1 Guide authored
3 Guide Comments
Would be really good to have one for the SSD
Andrew Hansford - Reply Share
I am thinking of expanding the storage on this model. If I get around to it I’ll post a guide
jort - Reply Share
For retail stores like me this is very helpful. I can send to customers so they can upgrade themselves. Thanks for sharing
My Website: Laptop Workstation cũ Tphcm
Laptop Titan - Reply Share
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 97
All Time: 5,337
