Hp Pavilion dv6-2155dx Optical Drive Replacement
    1. Hp Pavilion dv6-2155dx Optical  Drive Replacement, Optical Drive: step 1, image 1 of 2 Hp Pavilion dv6-2155dx Optical  Drive Replacement, Optical Drive: step 1, image 2 of 2
      • Flip the computer around to the back side.
      • Remove the three screws from the memory module cover.
      • Screws will not come out all the way.
      • All screws to loosen/removed in this guide will require a Phillips #01 screwdriver.
      Ask FixBot
    2. Hp Pavilion dv6-2155dx Optical  Drive Replacement: step 2, image 1 of 1
      • Remove the screw completely from the memory module panel to help release the Optical drive from the body of the computer.
      • The screw is 7mm long and head is 4mm wide.
      Ask FixBot
    3. Hp Pavilion dv6-2155dx Optical  Drive Replacement: step 3, image 1 of 2 Hp Pavilion dv6-2155dx Optical  Drive Replacement: step 3, image 2 of 2
      • Locate the small hole next to the eject button.
      • Get a paper clip and insert in to the small hole until you hear a clicking sound and seeing the tray pop out.
      • Before removing the optical drive, be sure that there is nothing in the drive. Optical drives are fragile so handle with care.
      Ask FixBot
    4. Hp Pavilion dv6-2155dx Optical  Drive Replacement: step 4, image 1 of 2 Hp Pavilion dv6-2155dx Optical  Drive Replacement: step 4, image 2 of 2
      • Gently pull the Optical drive out of the slot until the whole thing comes out.
      Ask FixBot
3 other people completed this guide.
Joseph Sanda
525 Reputation
4 Guides authored
UMass Dartmouth, Team 2-2, Isaacson Fall 2016 Member of UMass Dartmouth, Team 2-2, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 33
Past 30 Days: 113
All Time: 1,309
