Hp Mini 2133 Hard Disk Replacement
    1. Hp Mini 2133 Hard Disk Replacement, Battery: step 1, image 1 of 3 Hp Mini 2133 Hard Disk Replacement, Battery: step 1, image 2 of 3 Hp Mini 2133 Hard Disk Replacement, Battery: step 1, image 3 of 3
      • First power off the device.
      • And remove the battery.
      Ask FixBot
    2. Hp Mini 2133 Hard Disk Replacement, Remove the keyboard: step 2, image 1 of 2 Hp Mini 2133 Hard Disk Replacement, Remove the keyboard: step 2, image 2 of 2
      • Remove the screws
      • And open it up
      • Then disconect the cable for the key board.
      Ask FixBot
    3. Hp Mini 2133 Hard Disk Replacement, Cable for the keyboard: step 3, image 1 of 3 Hp Mini 2133 Hard Disk Replacement, Cable for the keyboard: step 3, image 2 of 3 Hp Mini 2133 Hard Disk Replacement, Cable for the keyboard: step 3, image 3 of 3
      • Now disconect the cable under the keyboard.
      • ATTENTION There is a lever to disconect the keyboard.
      Ask FixBot
    4. Hp Mini 2133 Hard Disk Replacement, Disconect the Disk: step 4, image 1 of 2 Hp Mini 2133 Hard Disk Replacement, Disconect the Disk: step 4, image 2 of 2
      • Now you throw from the plastic.
      Ask FixBot
    5. Hp Mini 2133 Hard Disk Replacement, Remove the protector: step 5, image 1 of 1
      • Now remove the protector.
      • The black screw does not come off completely.
      Ask FixBot
    6. Hp Mini 2133 Hard Disk Replacement, Remove the disk: step 6, image 1 of 2 Hp Mini 2133 Hard Disk Replacement, Remove the disk: step 6, image 2 of 2
      • Now remove the disk.
      • CAUTION WITH THE CONECTOR!
      Ask FixBot
    7. Hp Mini 2133 Hard Disk Replacement, Remove the conector from the disk: step 7, image 1 of 2 Hp Mini 2133 Hard Disk Replacement, Remove the conector from the disk: step 7, image 2 of 2
      • Now you remove the conector from the disk.
      Ask FixBot
Para reensamblar tu dispositivo, sigue estas instrucciones en orden inverso.
Guzmini
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 92
All Time: 955
