Hp 15-f305dx RAM Replacement
    1. Hp 15-f305dx RAM Replacement, Battery: step 1, image 1 of 1
      • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
      Ask FixBot
    2. Hp 15-f305dx RAM Replacement: step 2, image 1 of 1
      • Turn the computer upside down on a flat surface.
      Ask FixBot
    3. Hp 15-f305dx RAM Replacement: step 3, image 1 of 3 Hp 15-f305dx RAM Replacement: step 3, image 2 of 3 Hp 15-f305dx RAM Replacement: step 3, image 3 of 3
      • Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery.
      Ask FixBot
    4. Hp 15-f305dx RAM Replacement: step 4, image 1 of 2 Hp 15-f305dx RAM Replacement: step 4, image 2 of 2
      • Lift the battery from the middle and then pivot it outward to remove it from the computer.
      Ask FixBot
    1. Hp 15-f305dx RAM Replacement, RAM: step 5, image 1 of 1
      • Remove the two 5mm Phillips #00 screws on the back service cover.
      Ask FixBot
    2. Hp 15-f305dx RAM Replacement: step 6, image 1 of 2 Hp 15-f305dx RAM Replacement: step 6, image 2 of 2
      • With the hinge of the laptop screen facing away, remove the panel from the laptop on the near side of you.
      Ask FixBot
    3. Hp 15-f305dx RAM Replacement: step 7, image 1 of 3 Hp 15-f305dx RAM Replacement: step 7, image 2 of 3 Hp 15-f305dx RAM Replacement: step 7, image 3 of 3
      • Press the two locking arms on either side of the RAM card away from each other.
      • When the RAM is free from the locking arms, it should pop up to rest at an angle to the laptop.
      • Remove the RAM card by sliding it out from its port at the same angle at which it rests.
      • During reinstallation, insert the RAM card into the slot at the same angle which it rested earlier, then press it down until the locking arms clasp around it.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 65
All Time: 1,045
