Hp 15-f305dx Keyboard Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
0
Past 7 Days:
20
Past 30 Days:
65
All Time:
1,078
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Easy
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
If you need to replace the keyboard on your HP 15-f305dx laptop, use this guide.
The keyboard is the main way you interface with your computer. It is a crucial component in order effectively use a computer. There are several reasons why a keyboard may fail or stop working, including liquid, dust/debris, dropping the laptop, or bad hardware. All of these have the potential to cause a keyboard to fail resulting in the need for replacement.
Before using this guide, ensure your laptop’s battery has been removed so there is no chance of electric shock or further damage to your laptop.
Tools
    1. Hp 15-f305dx Keyboard Replacement, Battery: step 1, image 1 of 1
      • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
      Ask FixBot
    2. Hp 15-f305dx Keyboard Replacement: step 2, image 1 of 1
      • Turn the computer upside down on a flat surface.
      Ask FixBot
    3. Hp 15-f305dx Keyboard Replacement: step 3, image 1 of 3 Hp 15-f305dx Keyboard Replacement: step 3, image 2 of 3 Hp 15-f305dx Keyboard Replacement: step 3, image 3 of 3
      • Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery.
      Ask FixBot
    4. Hp 15-f305dx Keyboard Replacement: step 4, image 1 of 2 Hp 15-f305dx Keyboard Replacement: step 4, image 2 of 2
      • Lift the battery from the middle and then pivot it outward to remove it from the computer.
      Ask FixBot
    1. Hp 15-f305dx Keyboard Replacement, Keyboard: step 5, image 1 of 1
      • Flip the laptop around.
      Ask FixBot
    2. Hp 15-f305dx Keyboard Replacement: step 6, image 1 of 2 Hp 15-f305dx Keyboard Replacement: step 6, image 2 of 2
      • Remove the single 7 mm screw from the top middle of the laptop using a Phillips #0 screwdriver.
      Ask FixBot
    3. Hp 15-f305dx Keyboard Replacement: step 7, image 1 of 2 Hp 15-f305dx Keyboard Replacement: step 7, image 2 of 2
      • Pry the keyboard out of the laptop gently and flip the keyboard around.
      Ask FixBot
    4. Hp 15-f305dx Keyboard Replacement: step 8, image 1 of 1
      • Disconnect the connected cable from the mainboard.
      Ask FixBot
Brandon
681 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 20
Past 30 Days: 65
All Time: 1,078
