How to stop bicycle brakes from squeaking
    1. How to stop bicycle brakes from squeaking, How to stop bicycle brakes from squeaking: step 1, image 1 of 1
      • Loosen the brake pads from the calipers using a 10mm wrench.
      • You will need to repeat this step for the second brake pad located on the other side of the wheel.
      Ask FixBot
    2. How to stop bicycle brakes from squeaking: step 2, image 1 of 1
      • Remove the brake pads from the calipers.
      Ask FixBot
    3. How to stop bicycle brakes from squeaking: step 3, image 1 of 1
      • Clean the surface of the brake pad with a cloth or water if necessary.
      • The surface of the rims where the brake pads make contact may also need to be cleaned.
      Ask FixBot
    4. How to stop bicycle brakes from squeaking: step 4, image 1 of 1
      • Reattach the brake pads to the calipers and tighten them with the 10mm wrench so that the leading edge of the brake sits closer to the rim than the rear edge.
      Ask FixBot
    5. How to stop bicycle brakes from squeaking: step 5, image 1 of 1
      • Check the brake cable and make sure that it is still connected and secured to the brake calipers.
      Ask FixBot
    6. How to stop bicycle brakes from squeaking: step 6, image 1 of 1
      • Test the brake to ensure that it functions properly before riding the bike.
      Ask FixBot
Kevin Colon
160 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 11
Past 30 Days: 53
All Time: 2,325
