How to shorten shirt straps
    1. How to shorten shirt straps, How to shorten shirt straps: step 1, image 1 of 3 How to shorten shirt straps, How to shorten shirt straps: step 1, image 2 of 3 How to shorten shirt straps, How to shorten shirt straps: step 1, image 3 of 3
      • Put on the shirt.
      • Pull the strap up until you reach your new desired length. Be sure to take the same amount of fabric from the front and the back of the seam.
      • Pin both straps to the desired length.
      Ask FixBot
    2. How to shorten shirt straps: step 2, image 1 of 2 How to shorten shirt straps: step 2, image 2 of 2
      • Remove the shirt.
      • Be careful of the pins when taking off the shirt.
      • Measure and take a note of the length. Make sure it is the same on both straps.
      • This length will be the amount your strap that will be removed.
      Ask FixBot
    3. How to shorten shirt straps: step 3, image 1 of 3 How to shorten shirt straps: step 3, image 2 of 3 How to shorten shirt straps: step 3, image 3 of 3
      • Remove the pins and flip the shirt inside out.
      • Re-pin both shirt straps. Make sure the pins follow the measurements you just took.
      • Make sure you have a clear line to sew along.
      • Check and make sure the base of the straps are lined up for a continuous edge on your shirt.
      Ask FixBot
    4. How to shorten shirt straps: step 4, image 1 of 3 How to shorten shirt straps: step 4, image 2 of 3 How to shorten shirt straps: step 4, image 3 of 3
      • Thread the sewing machine and set it to your desired stitch length.
      • Refer to your specific sewing machine manual for more guidance.
      • Align the pinned part of the shirt with the needle.
      • Put down the presser foot.
      Ask FixBot
    5. How to shorten shirt straps: step 5, image 1 of 2 How to shorten shirt straps: step 5, image 2 of 2
      • Sew along the line mapped out by your pins.
      • Pull out the pins as you sew. Make sure not to sew over any of them.
      • If you sew over the pins, you may break the needle.
      • Make sure to backstitch at each end of the seam.
      • Repeat this step for each strap.
      Ask FixBot
    6. How to shorten shirt straps: step 6, image 1 of 1
      • Put the shirt back on.
      • Confirm the new length that you chose for the garment.
      • If the straps are too still long or short, carefully rip out your new seam and return to Step 1.
      Ask FixBot
    7. How to shorten shirt straps: step 7, image 1 of 3 How to shorten shirt straps: step 7, image 2 of 3 How to shorten shirt straps: step 7, image 3 of 3
      • Cut excess fabric from the new seams, leaving ¼ inch to ½ inch.
      • Iron the seam allowance left after your cut to the back of the shirt.
      Ask FixBot
    8. How to shorten shirt straps: step 8, image 1 of 1
      • Flip the shirt right side out.
      • Make a straight stitch approximately 1/8 inch behind the new shoulder seam on the outside edge.
      • Make sure your new seam properly secures the seam allowance underneath.
      Ask FixBot
    9. How to shorten shirt straps: step 9, image 1 of 1
      • Cut any loose threads on the shirt.
      Ask FixBot
Your shirt straps now should be secured at their new length.
2 other people completed this guide.
Natalie Clark
227 Reputation
1 Guide authored
Cal Poly, Team 15-2, Green Fall 2015 Member of Cal Poly, Team 15-2, Green Fall 2015
CPSU-GREEN-F15S15G2
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 45
Past 30 Days: 149
All Time: 12,844
