Up to 20% off select tools
How to set up a warning triangle
Views: 5.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
50
Past 30 Days:
237
All Time:
5,470
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
A warning triangle is a safety device that is used to alert other drivers on the road of a potential hazard or obstruction ahead. It is usually placed behind a vehicle that has broken down, been involved in an accident, or is otherwise not able to move under its own power. The warning triangle helps to make other drivers aware of the danger so that they can slow down or take evasive action to avoid a collision. Some countries require drivers to carry a warning triangle in their vehicles at all times, so it is always a good idea to check the local regulations before setting out on a road trip.
    1. How to set up a warning triangle, Put on a safety vest: step 1, image 1 of 1
      • Take a safety vest and put it on. You can usually find one in or near your vehicle safety/first aid kit.
      Ask FixBot
    2. How to set up a warning triangle, Take out the warning triangle: step 2, image 1 of 2 How to set up a warning triangle, Take out the warning triangle: step 2, image 2 of 2
      • You can usually find your warning triangle in a compartment on the left side of your boot. On some older cars you might also find it in the tailgate or on top of the reserve wheel under the boot.
      • Sometimes the warning triangle and first aid kit come together in a compact combi-pack. Then the warning triangle will be in a red tube in the first aid bag.
      • Since the position of the warning triangle varies from car to car, you should read the manual and memorize where the first aid kit and warning triangle are stashed in your car, before you get into an accident, so that you don’t have to waste time searching.
      Ask FixBot
    3. How to set up a warning triangle, Unpack and unfold the warning triangle: step 3, image 1 of 2 How to set up a warning triangle, Unpack and unfold the warning triangle: step 3, image 2 of 2
      • Outside the dangerous area, ideally beyond the crash barrier, unpack and fully unfold the warning triangle.
      • Depending on the design, twist the two lower bars in the middle until they form a cross, or fold out the four feet - 2 each at the bottom corners of the triangle - forwards and backwards until the warning triangle can be set up stably.
      • Above the base are the three red bars. Two of them can be pulled up and locked together to form the legs of the triangle. The plastic inner film folds open automatically.
      • In order not to forget the warning triangle when driving off, you should put the packaging on the driver's seat - so you remember it immediately when you get in.
      Ask FixBot
    4. How to set up a warning triangle, Setting up the warning triangle: step 4, image 1 of 1
      • Walk towards traffic while keeping the warning triangle visible in front of you, ideally at chest height.
      • Only walk at the very edge of the lane, ideally behind the crash barrier.
      • Now set it up on the roadside - the distance to the vehicle should be around 50 meters in urban areas, 100 meters on country roads and at least 150 meters on the motorway.
      Ask FixBot
Drive safe!
Author
with
Sebastian
33,969 Reputation
72 Guides authored
1 Guide Comment
Excellent job describing things most people (and writers) don't think of.
Terra - Reply Share
Past 24 Hours: 4
Past 7 Days: 50
Past 30 Days: 237
All Time: 5,470
