How to restore UV Damaged Headlights
  1. How to restore UV Damaged Headlights, How to restore UV Damaged Headlights: step 1, image 1 of 3 How to restore UV Damaged Headlights, How to restore UV Damaged Headlights: step 1, image 2 of 3 How to restore UV Damaged Headlights, How to restore UV Damaged Headlights: step 1, image 3 of 3
    • In a shaded area, apply masking tape on the outer edges of the headlight assembly.
    Ask FixBot
  2. How to restore UV Damaged Headlights: step 2, image 1 of 3 How to restore UV Damaged Headlights: step 2, image 2 of 3 How to restore UV Damaged Headlights: step 2, image 3 of 3
    • Use the spray bottle of soapy water to wet the 800-grit sandpaper.
    • Spray the sandpaper liberally and make sure it is completely wet.
    Ask FixBot
  3. How to restore UV Damaged Headlights: step 3, image 1 of 3 How to restore UV Damaged Headlights: step 3, image 2 of 3 How to restore UV Damaged Headlights: step 3, image 3 of 3
    • Spray the headlight with soapy water and sand the headlight's surface.
    • Continuously spray the headlight and the sandpaper with water. The surface must stay wet during sanding.
    • Sand the headlight in a circular motion throughout this step.
    • Stop sanding when the entire headlight appears foggy.
    Ask FixBot
  4. How to restore UV Damaged Headlights: step 4, image 1 of 3 How to restore UV Damaged Headlights: step 4, image 2 of 3 How to restore UV Damaged Headlights: step 4, image 3 of 3
    • Spray the 2000-grit sandpaper with soapy water and ensure it is completely wet.
    • Sand the headlight in a circular motion while maintaining the surface wet with soapy water.
    • Stop sanding when the headlight appears slightly less cloudy (than in the previous step).
    Ask FixBot
  5. How to restore UV Damaged Headlights: step 5, image 1 of 3 How to restore UV Damaged Headlights: step 5, image 2 of 3 How to restore UV Damaged Headlights: step 5, image 3 of 3
    Tool used on this step:
    Microfiber Cleaning Cloths
    $3.99
    Buy
    • Lightly wet a small section of a clean microfiber cloth with 70% isopropyl alcohol.
    • Rub down the entire headlight surface with the microfiber cloth.
    Ask FixBot
  6. How to restore UV Damaged Headlights: step 6, image 1 of 2 How to restore UV Damaged Headlights: step 6, image 2 of 2
    • Carefully peel off the old masking tape.
    • Use newspaper to cover the car's body using masking tape to hold it down.
    • Shield any gaps and use newspapers at least a foot long.
    • The newspaper will protect the car from overspray in the next step.
    Ask FixBot
  7. How to restore UV Damaged Headlights: step 7, image 1 of 3 How to restore UV Damaged Headlights: step 7, image 2 of 3 How to restore UV Damaged Headlights: step 7, image 3 of 3
    • Use a clear coat to spray the headlight.
    • Follow the clear coat manufacturer's instructions for spraying distance, number of coats, and drying time.
    • Apply the clear coat in well-ventilated conditions.
    Ask FixBot
  8. How to restore UV Damaged Headlights: step 8, image 1 of 3 How to restore UV Damaged Headlights: step 8, image 2 of 3 How to restore UV Damaged Headlights: step 8, image 3 of 3
    • Apply a small amount of compound to a clean microfiber applicator pad.
    • Dap the headlight's surface with the compound.
    • Work the compound into the headlight.
    • Use heavy pressure and rub in a circular motion when working the compound into the headlight.
    Ask FixBot
  9. How to restore UV Damaged Headlights: step 9, image 1 of 3 How to restore UV Damaged Headlights: step 9, image 2 of 3 How to restore UV Damaged Headlights: step 9, image 3 of 3
    • Wipe the headlight with a clean microfiber cloth.
    • Apply a small amount of polish onto a new, clean microfiber applicator pad.
    • Dap the polish onto the headlight, then work the polish onto the headlight.
    Ask FixBot
  10. How to restore UV Damaged Headlights: step 10, image 1 of 3 How to restore UV Damaged Headlights: step 10, image 2 of 3 How to restore UV Damaged Headlights: step 10, image 3 of 3
    • Wipe the headlight with the clean side of a microfiber cloth.
    • Use a microfiber cloth to scoop about a quarter-sized amount of wax.
    • Rub the wax into the headlight with medium pressure and in a circular motion.
    • Continue rubbing until there is no more visible wax.
    Ask FixBot
  11. How to restore UV Damaged Headlights: step 11, image 1 of 3 How to restore UV Damaged Headlights: step 11, image 2 of 3 How to restore UV Damaged Headlights: step 11, image 3 of 3
    • Wipe the headlight with a clean side of microfiber cloth.
    • Carefully remove the newspaper and masking tape.
    • Enjoy the clear road with your newly restored headlights!
    Ask FixBot
4 other people completed this guide.
1 Guide Comment
Greetings and thank you for such a comprehensive guide on cleaning the head lights of a vehicle
Peter Jafta - Reply Share
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 99
All Time: 2,666
