This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
How to reset the print counter to zero
Views: 1.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
8
Past 30 Days:
42
All Time:
1,469
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide explains how to reset the counter of a Ricoh Aficio SP C242 printer cartridge by reprogramming its EEPROM memory with an Arduino Uno board. This operation modifies the cartridge data: check the wiring carefully and select the correct color before starting the programming.
    1. How to reset the print counter to zero, Find the electronic contact card: step 1, image 1 of 1
      • On the side of the cartridge is a small electronic contact card with 4 contacts.
      • For those who are interested in transposing on other models, at the back of the contact card point is a EEPROM BR24L01A-W type memory.
      Ask FixBot
    2. How to reset the print counter to zero, Prepare the Arduino: step 2, image 1 of 2 How to reset the print counter to zero, Prepare the Arduino: step 2, image 2 of 2
      • The EDPROM can be reprogrammed thanks to an Arduino UNO card, for instance.
      • Prepare an Arduino UNO card with the following pins:
      • Pin 1 (SCL) connected to A5
      • Pin 2 (SDA) connected to A4
      • Pin 3 (5V) connected to the 5V port on the Arduino card
      • Pin 4 (GND) connected to GND on the Arduino card.
      Ask FixBot
    3. How to reset the print counter to zero, Programming: step 3, image 1 of 1
      • Download the ICI program file
      • Start Arduino and open the .ino file
      • Upload the program to the Arduino Uno board
      • Launch the serial monitor via the button at the top right
      • Make contact on the cartridge card. The 4 contacts need to work well at the same time
      • Follow the instructions to reprogram the memory according to the correct color (Black, Cyan, Magenta, Yellow)
      Ask FixBot
By reinstalling the cartridge in the printer, it identifies it as 100% full!
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
MattMich
31 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 8
Past 30 Days: 42
All Time: 1,469
