How to reset the Tchibo Cafissimo machine
Views: 150K
View statistics:
Past 24 Hours:
30
Past 7 Days:
137
Past 30 Days:
611
All Time:
149,965
Comments: 19
8 comments on steps, 11 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Introduction
Go to step 1 ↓
Follow this guide to reset your Tchibo Cafissimo coffee machine.
      • Switch the machine off and open the big metallic lever to begin.
      Ask FixBot
      • Press and hold the espresso button (the one on top of the 3 coffee buttons), then switch the machine on.
      • If this doesn't work, repeat this step while pressing the two top coffee buttons instead.
      Ask FixBot
      • Close the big lever and open it again. You might have to repeat it twice in order for it to work.
      • If this worked, you'll hear a beep indicating that the machine has been reset.
      Ask FixBot
If it doesn't work first time, just try again.
4 other people completed this guide.
Schlauer Bauer
124 Reputation
1 Guide authored
11 Guide Comments
For a tchibo cafissimo classic?
yasmin isabelle - Reply Share
Hat überhaupt gar nicht funktioniert.
Bei meiner TchiboS Cafissimo classic sind auch die 3 Kaffeewahlknöpfe auf gleicher Höhe und es gibt somit keinen „obersten“ Knopf.
Kobe - Reply Share
My machine is not working and the button light is blinking
Shouyab Shahin - Reply Share
Not working,the lever has no switch or sensor so it doesn`t metter.Mine is flashing red with no beep and not respond to command.The level sensor for wather is ok,the temperature senzor from boiler is ok,the resistence of boiler is ok..so..maybe the software is the problem
Cici - Reply Share
Bei meiner Tchibo 288032 für fertige Kapseln leuchteten die Dioden rechts neben dem Einschaltknopf nicht mehr.
Die Ursache dafür war ein fehlender Magnet im Wasserbehälter. Die Maschine “dachte” sie hätte kein Wasser obwohl der Behälter voll war.
Erst nach dem Wiedereinsetzen des schwarzen Magneten gingen die Leuchten an und alles funktionierte wieder.
Er musste im Geschirrspüler, oder während der Reinigungsarbeiten abgeflogen sein, wurde aber gefunden.
Zunächst wurde er nicht identifiziert und beiseite gelegt.
Hinter der Plastikwand befindet sich ein Hamlin Reedschalter, der durch das Magnetfeld den Kontakt schliesst.
Olki - Reply Share
Past 24 Hours: 30
Past 7 Days: 137
Past 30 Days: 611
All Time: 149,965
