Community-Contributed Guide
Introduction
Go to step 1 ↓A faulty temperature sensor can leave your oven stone-cold or turn it into a cremator. Replacing the sensor restores accurate heat control so your food bakes as intended. Follow this procedure to swap the plug-type sensor found in many built-in ovens and the capillary-tube thermostat used in older freestanding stoves.
Step 1 Disconnect power and remove the built-in oven
Slide the built-in oven out of the cabinet to expose the back panel.
Step 3 Disconnect the temperature sensor plug
Unplug the temperature sensor connector located on the back wall.
Step 4 Release and extract the sensor
Remove one sensor retaining screw completely and loosen the other slightly.
Pull the sensor straight out of the oven cavity.
Step 5 Install the new sensor
Insert the new sensor through the opening until its eyelet seats flush.
Tighten both retaining screws to secure the sensor.
Reconnect the sensor plug to the wiring harness.
Step 6 Reassemble the built-in oven
Reinstall the rear panels with their screws.
Push the oven back into the cabinet in its original position.
Step 7 Remove knob and record thermostat orientation
Pull off the temperature control knob on the freestanding stove.
Step 8 Detach the thermostat from the control panel
Unscrew and remove the thermostat from the control panel.
Step 10 Remove the analog sensor and capillary tube
Inside the oven, loosen the screw securing the sensor bulb and withdraw it.
Carefully guide the capillary tube out along its original path.
Step 11 Disconnect the tube from the thermostat
Disconnect the tube and remove the old thermostat from the stove.
Step 12 Fit the new thermostat and sensor
Lightly attach the new thermostat to the control panel.
Route the capillary tube gently to the oven cavity following the original path.
Seat the sensor bulb and tighten its retaining screw.
Fully tighten the thermostat mounting screws when alignment is correct.
Step 13 Close the stove housing
Lower the cooktop and reinstall its side screws.
Push the control knob back onto the thermostat shaft in the recorded orientation.
With a new temperature sensor fitted, your oven should now reach and hold the set temperature, ending under- or over-baked meals. Always unplug the appliance before future work, and treat sharp panels and fragile capillary tubes with care to keep both you and the stove in good shape.
