How to replace the temperature sensor in your dishwasher
    • Unplug the dishwasher from the mains before any work begins.
    • Never touch internal wiring with the appliance connected.
    Ask FixBot
    • Compare wash water temperature with program settings; unexpected cold cycles indicate a faulty sensor.
    • Symptoms are almost identical to a failed heating element, so rule that out first.
    Ask FixBot
    • Look for the sensor near the heater on the tub floor in roughly ninety percent of models.
    • If it is not on the tub floor, inspect the door panel because some machines place the sensor there.
    • Most sensors are found underneath the tub, near the heating element, or inside the door. If you're unsure, check the device page of your specific model for diagrams.
    Ask FixBot
    • Unscrew or unclip the lower decorative plate to expose the sensor mounting area.
    Ask FixBot
    • Determine whether the part is a bimetal thermostat, an NTC probe, or a combined design used in some models.
    • Expect an NTC probe to cost around fifteen euros depending on the spare‑parts supplier.
    • Release the sensor clip and pull the sensor straight out of the housing.
    • Keep the rubber gasket on the sensor for reference or reuse.
    Ask FixBot
    • Press the rubber gasket fully into the tub opening to prevent leaks.
    • Push the new sensor into place until it locks flush with the gasket.
    Ask FixBot
    • Tighten the sensor retaining ring or fasteners evenly without over‑torquing.
    • Reconnect the two sensor wires; polarity is irrelevant on NTC probes.
    • For thermostat types match the colored dot or markings recorded during removal to keep correct orientation.
    Ask FixBot
    • Reattach the decorative plate and its fasteners to restore the dishwasher’s appearance.
    Ask FixBot
    • Restore power, run a short wash cycle, and confirm the appliance reaches the correct temperatures.
    • Monitor for leaks around the sensor sealing area during the first cycle.
    • If the machine still misbehaves, consult a qualified technician.
    Ask FixBot
With the new sensor fitted, your dishwasher should heat water correctly and clean efficiently again. Always document any repairs for warranty purposes and keep the old part for comparison. If uncertain at any stage, stop and seek professional help—safety and warranty compliance remain your responsibility.
Ula Gantar
16,609 Reputation
81 Guides authored
ZEOS Slovenia Member of ZEOS Slovenia
Local Repair Groups
2 Members
164 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 122
All Time: 904
