How to replace the main fuse in your microwave
      • Microwave ovens contain a high-voltage capacitor that can hold over 2000 V even when unplugged and can cause fatal shock.
      • Only replace the main fuse; leave all other microwave repairs to trained technicians.
      • Unplug the microwave from the mains outlet before you begin any work.
      Ask FixBot
      • Remove every screw that secures the metal cabinet to the chassis, checking all sides and the rear for fasteners.
      • Different models use different screw types and positions, so inspect the entire perimeter of the housing.
      • Lift the cabinet straight back and off to expose the internal components while avoiding contact with them.
      Ask FixBot
      • Find the cylindrical fuse mounted in a clip near the top or side of the chassis, often next to a board marking labelled “FUSE”.
      • Keep your hands and tools away from all other components to avoid high-voltage hazards.
      Ask FixBot
      • Read the voltage and current values on the removed fuse or on the board; typical ratings are 250 V and 8 A.
      • Replace the fuse only with one that matches both the voltage and amperage exactly to maintain safety.
      • Purchase the correct fuse from an electronics parts supplier before proceeding.
      Ask FixBot
      • Inspect glass fuses for a broken filament or dark burn marks as an initial check.
      • Set a multimeter to continuity or beep mode and place the probes on each end of the fuse.
      • A beep indicates continuity, while silence confirms the fuse is open and must be replaced.
      Ask FixBot
      • Grip the replacement fuse with insulated pliers and align it with the spring clips.
      • Press the fuse gently into place until it is fully seated without twisting the clips.
      Ask FixBot
      • Reposition the metal cabinet and reinstall every screw removed earlier, tightening them securely.
      • Never power or test the microwave with the cabinet removed.
      Ask FixBot
With the cabinet securely reinstalled, plug the microwave back in and test its operation. If the new fuse opens immediately or the unit still fails to run, discontinue use and contact a qualified service technician for further diagnosis.
Ula Gantar
16,636 Reputation
81 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 87
Past 30 Days: 306
All Time: 1,001
