Up to 20% off select tools
How to replace the door knob
Views: 3K
View statistics:
Past 24 Hours:
7
Past 7 Days:
32
Past 30 Days:
194
All Time:
3,011
Comments: 1
1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Easy
Community-Contributed Guide
    1. How to replace the door knob, Remove the screw holding the handle: step 1, image 1 of 1
      • It is advisable to work with two people, one holding the outer handle on the outside and the other unloading the screw on the other side.
      • Remove the two screws.
      Ask FixBot
    2. How to replace the door knob, Remove the handle: step 2, image 1 of 1
      • Use pry bar carefully pry around, you can remove both sides of the door handle.
      • There is usually a plastic washer between the handle and the door, taking care not to damage it.
      • There will be a metal square shaft connected between the handle. Be careful not to lose it when removing the inside handle because the shaft is inside and outside.
      Ask FixBot
    3. How to replace the door knob, Pay attention to the square shaft: step 3, image 1 of 1
      • Pay attention to the installation direction of this square shaft. Do not knock it off when removing the handle.
      Ask FixBot
Reversing the steps to know hot to install the know. It's easier than your thought , isn't it?
6 other people completed this guide.
Special thanks to these translators:
zh en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Z.Heng
4,317 Reputation
3 Guides authored
1 Guide Comment
图文并茂,生动形象,谢谢你的分享!
Conti - Reply Share
Past 24 Hours: 7
Past 7 Days: 32
Past 30 Days: 194
All Time: 3,011
