How to repair the GM VATS control module
  1. How to repair the GM VATS control module, Remove the module: step 1, image 1 of 1
    • Picture #1: Remove the VATS MODULE
    Ask FixBot
  2. How to repair the GM VATS control module, Open the module cover: step 2, image 1 of 1
    • Open Module being careful not to break off these two tabs
    Ask FixBot
  3. How to repair the GM VATS control module, Seperate board from the box: step 3, image 1 of 1
    • The board lifts straight up out of the box
    Ask FixBot
  4. How to repair the GM VATS control module, Re-solder. You will find this joint will not easily accept solder.: step 4, image 1 of 1
    • The tip of the screw driver is at the joint that has failed. Generally I re-flow the solder on all 7 of the larger diodes and both of the blue color resistors in between the diodes. I also re-flow all the joints on the black wire harness connector.
    Ask FixBot
  5. Tool used on this step:
    Desoldering Pump
    $3.99
    Buy
    • If the solder will not flow smoothly on any of the joints, the joint will require cleaning. Mark the direction the diode is in and remove the solder from the joints using a solder sucker. Remove diode. Add flux and brush the area being very careful not to damage the eyelets on the board.
    Ask FixBot
  6. How to repair the GM VATS control module, Reassemble and start the vehicle.: step 6, image 1 of 1
    • You may even have to use a pencil eraser. Be sure not to damage the eyelets on the board. After it is clean reinstall the diode in the same direction (silver band toward the edge of the board) and solder in place. Place the board back inside the box and close the lid. Plug it into the harness and start the engine.
    Ask FixBot
Ed D
313 Reputation
1 Guide authored
4 Guide Comments
I have a 1998 chevy k1500. Removed module about a year ago, and truck had run fine till I unhooked battery for something else, without module connected, about a week later truck stopped running it will run for a few seconds and die. Tried to reinstall module and relearn with key but nothing. Is this because battery was disconnected without the module. If so how can I fix this?
Thanks
Adam - Reply Share
I'm sorry I didn't read this question until today.
Anyway the 1998 Chevy K1500 is a different system than this older PATS design. Your system has a learning feature and by following the relearn procedure, it will relearn the key or New Key/Lock cylinder you are installing. I have run into only one problem over the years that does not allow the relearn to "Start". It is because the plastic switch mounted in the housing above the lock cylinder is worn or broken off and does not register the key is inserted. It is a simple on/off switch and can be tested mounted in the housing or remover, but removing the switch can give you a false positive test because the button may be wore enough to prevent the key from pressing upward enough to open the contacts.
The switch is small, white, two wire and located in the ignition key housing, directly above the key. It was to be rotated to removed. In that housing you'll see three wires plugged in and the white switch to the right and in. I don't see any way to post pictures.
Ed D - Reply Share
Will this stop my keyless entry my fob not to work when I turn the ignition on three times and then try to reset my fob. It doesn’t work unlocks the trunk and the driver side door and the passenger door stays locked. I put a new body control modular in and still having the same problem, can’t figure it out.
Gmjoe - Reply Share
Not sure if you’re still active, but would this repair be compatible with my 1993 Deville? Pretty sure it’s the PASS-key II system
Christian Campos - Reply Share
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 92
All Time: 3,960
