How to repair AC leaks
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
89
All Time:
1,276
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to analyze and repair AC leaks.
AC system leaks occur most frequently when one or more components malfunction. It's possible that one of your system's drain pans is cracked, or that your air filter or drain line is clogged, or AC sputters. These problems may lead to refrigerant leaks that impair the functionality of your system and reduce its effectiveness. Long-term issues that could arise if you don't repair your leaky AC unit include:
  • A costly AC system repair bill
  • Higher energy bills and increased energy use
  • Exposure to substances that can harm your lungs and cause burns
  • Damaging emissions that could harm the environment
With this guide you will be taken on a step by step procedure on how to safely and easily asses and repair any and all problems that your AC may have.
Be advised!, if after a complete DIY diagnosis of your AC, if problem turns out to be a refrigerant leak, refrain from fixing on your own. Highly recommended to consult professional help to avoid costly mistakes.
    1. How to repair AC leaks, How to repair AC leaks: step 1, image 1 of 1
      • Check the drain pan for cracks or rust. If any are visible, using an epoxy putty on the small holes can be then patched. If the damage is severe then the pan will need to be replaced.
      Ask FixBot
    2. How to repair AC leaks: step 2, image 1 of 2 How to repair AC leaks: step 2, image 2 of 2
      • If the drain line is clogged. Firstly, advised to check the AC manual to find where the drain pipe is. Using a long, thin, and flexible object, such as a flexible drain brush, clean the drain pipe of all the dirt.
      Ask FixBot
    3. How to repair AC leaks: step 3, image 1 of 2 How to repair AC leaks: step 3, image 2 of 2
      • Check the filter for ice and dirt, wash the filter thoroughly as most AC filters are washable. If there is excess ice and dirt, replacing the filter is advised.
      Ask FixBot
    4. How to repair AC leaks: step 4, image 1 of 1
      • Check the outside unit for dirt buildup and or any damage. In most cases, a thorough wash will be more than enough.
      Ask FixBot
    5. How to repair AC leaks: step 5, image 1 of 1
      • If the AC is showing signs of hard starting, such as sputters or turning on the AC then suddenly shutting off. Using a hard start kit on the compressor will do wonders to include prolonging the lifespan of the AC.
      Ask FixBot
    6. How to repair AC leaks: step 6, image 1 of 1
      • Last but not least, check the AC exhaust duct for loose ends, cracks, and dirt build up. Clean thoroughly as if clogged or damage since that can cause leaks in the AC as well as cause health problems to the home occupants.
      Ask FixBot
For reassembly, just reverse disassembly steps.
Ash
163 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 89
All Time: 1,276
