How to region unlock your Nintendo 64
Video Overview
    1. How to region unlock your Nintendo 64, Top Cover: step 1, image 1 of 1
      • Remove the expansion pack cover by pushing in the tab and pulling out.
      Ask FixBot
    2. How to region unlock your Nintendo 64: step 2, image 1 of 1
      • If your system uses a jumper pack, the same procedure applies to remove it.
      • A small spoon can be used in place of a spudger.
      • Lever the expansion pack out using a metal spudger.
      Ask FixBot
    3. How to region unlock your Nintendo 64: step 3, image 1 of 1
      • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
      Ask FixBot
    4. How to region unlock your Nintendo 64: step 4, image 1 of 1
      • Remove the two front feet of the N64.
      Ask FixBot
    5. How to region unlock your Nintendo 64: step 5, image 1 of 1
      • Rotate to top side up and lift off top cover.
      Ask FixBot
    1. How to region unlock your Nintendo 64, How to region unlock your Nintendo 64: step 6, image 1 of 2 How to region unlock your Nintendo 64, How to region unlock your Nintendo 64: step 6, image 2 of 2
      • Flip the top over and locate the two screws that hold the current slot in place.
      • Remove the slot with a normal Phillips head screwdriver.
      Ask FixBot
      • To install the new slot, simply place the new slot in the same location as the old one.
      • Ensure that the new slot aligns with the opening on the top of the console.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order and enjoy your region-unlocked console.
Additional Information
6 other people completed this guide.
Jacob Mehnert
49,951 Reputation
52 Guides authored
iFanatics Member of iFanatics
Community
69 Members
1,151 Guides authored
1 Guide Comment
If you don't want to buy a region-unlocked tray, there are two black, square-shaped nubs under the gray cartridge slot covers that can be sanded off with a Dremel tool or sandpaper.
FleshyPie64 - Reply Share
Past 24 Hours: 9
Past 7 Days: 80
Past 30 Days: 312
All Time: 33,445
