How to realign HP Photosmart D110a scanner
  1. How to realign HP Photosmart D110a scanner, Printer Hood Assembly: step 1, image 1 of 1
    • Pull down both front panels to open the printer. Lift the scanner flap upward by pulling down on it; there are two mouth pieces that need to be pulled down.
    • Adjust the flap covering the scanner upward, as shown.
    Ask FixBot
  2. How to realign HP Photosmart D110a scanner: step 2, image 1 of 1
    • Pull the scanner flap gently away from the printer to release its two clips.
    Ask FixBot
  3. How to realign HP Photosmart D110a scanner: step 3, image 1 of 1
    • Locate the three screws on top of the printer.
    • The orange circle shows a fourth screw located behind the power panel. Ignore this one for now, as directions to remove this screw are in Step 5.
    Ask FixBot
  4. How to realign HP Photosmart D110a scanner: step 4, image 1 of 3 How to realign HP Photosmart D110a scanner: step 4, image 2 of 3 How to realign HP Photosmart D110a scanner: step 4, image 3 of 3
    • Using a T-9 screwdriver, remove the three screws from the printer's top.
    Ask FixBot
  5. How to realign HP Photosmart D110a scanner: step 5, image 1 of 2 How to realign HP Photosmart D110a scanner: step 5, image 2 of 2
    • To remove the power button panel:
    • Reach inside the printer's front opening.
    • Press the small clip behind the power button.
    • A picture of the power button panel removed is provided to show the location of the clip that needs to be pressed.
    • Pull the panel out from right to left.
    Ask FixBot
  6. How to realign HP Photosmart D110a scanner: step 6, image 1 of 2 How to realign HP Photosmart D110a scanner: step 6, image 2 of 2
    • Remove the fourth screw, which was covered by the power button panel.
    • Do not try and torque the screw from an angle. This will ruin the screw's head, and make it even more difficult to remove the screw. Only remove it as already described.
    • This screw is placed awkwardly. We found holding a T9 bit in a pair of needle nose pliers gave us enough leverage to pull it up.
    Ask FixBot
  7. How to realign HP Photosmart D110a scanner: step 7, image 1 of 3 How to realign HP Photosmart D110a scanner: step 7, image 2 of 3 How to realign HP Photosmart D110a scanner: step 7, image 3 of 3
    • With a partner's help:
    • Have one person lift the hood 2-3 inches.
    • Have the other person disconnect the three cables from the motherboard (the green PCB) to the hood by gently pulling upward on them.
    • Remove the hood completely.
    Ask FixBot
  8. How to realign HP Photosmart D110a scanner, Printer Hood: step 8, image 1 of 3 How to realign HP Photosmart D110a scanner, Printer Hood: step 8, image 2 of 3 How to realign HP Photosmart D110a scanner, Printer Hood: step 8, image 3 of 3
    • Remove the single T-9 screw from the hood's underside, as shown.
    Ask FixBot
  9. How to realign HP Photosmart D110a scanner: step 9, image 1 of 2 How to realign HP Photosmart D110a scanner: step 9, image 2 of 2
    • With the screw removed, separate the two pieces of the hood by lifting it vertically.
    • Only lift the the top piece enough so that there is no tension applied to the ribbon cables shown.
    • Carefully pull down the white ribbon cable through the top piece of the hood.
    Ask FixBot
  10. How to realign HP Photosmart D110a scanner: step 10, image 1 of 2 How to realign HP Photosmart D110a scanner: step 10, image 2 of 2
    • Separate the hood pieces while keeping the black ribbon cable connected. Rest the scanner piece carefully to avoid stressing its ribbon cable.
    Ask FixBot
  11. How to realign HP Photosmart D110a scanner, How to realign HP Photosmart D110a scanner: step 11, image 1 of 3 How to realign HP Photosmart D110a scanner, How to realign HP Photosmart D110a scanner: step 11, image 2 of 3 How to realign HP Photosmart D110a scanner, How to realign HP Photosmart D110a scanner: step 11, image 3 of 3
    • After having the hood removed and disassembled, locate the scanner.
    • Adjust the scanner wheel such that fits into the path.
    • If the black ribbon cable is twisted, untwist it so it appears as shown.
    Ask FixBot
2 other people completed this guide.
Tim Wise
173 Reputation
7 Guides authored
Cal Poly, Team 10-38, Forte Spring 2011 Member of Cal Poly, Team 10-38, Forte Spring 2011
CPSU-FORTE-S11S10G38
5 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 64
All Time: 3,833
