How to prep and clone SSD with MacOS Catalina
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. How to prep and clone SSD with MacOS Catalina, Prep: step 1, image 1 of 1
      • Hardware needed:
      • SSD of greater size than existing used data.
      • Sata SSD to USB adapter
      Ask FixBot
      • Plug in the new SSD via the adapter
      • Ensure you have Catalina installed currently on your Mac
      Ask FixBot
    2. How to prep and clone SSD with MacOS Catalina, Install Catalina on the New SSD: step 3, image 1 of 1
      • Boot to recovery by holding cmd + r immediately after the device boots up. Hold until you see the apple logo
      • Choose Reinstall macOS
      Ask FixBot
      • BE SURE TO INSTALL TO THE NEW DRIVE
      • Do not reinstall to your existing drive
      • The reason to do this is to set up the file structure in the specific way that Catalina needs
      Ask FixBot
    3. How to prep and clone SSD with MacOS Catalina, Disk Utility: step 5, image 1 of 1
      • Once the new SSD has catalina on it
      • Exit the setup menu, power off
      • Reboot to recovery mode using the same cmd + R method as before.
      • Use the top menu View>>Show All Devices
      Ask FixBot
    4. How to prep and clone SSD with MacOS Catalina, Clone/Restore: step 6, image 1 of 1
      • Since there are two partitions this step will be done twice.
      • Select the new (currently external) SSD that has catalina on it. Select the first partition. I've called my disk MacGuyver
      • Then Click restore and choose the corresponding partition on your existing Catalina disk still installed in the computer
      • Once that is complete Repeat the recovery process for the second partition, this may have the word - Data on the end of the named disk.
      • This step is critical. The goal is to recover your data from the old drive to the new drive. Catalina uses two partitions, so the step must be done twice. This can take a while...
      Ask FixBot
    5. Ask FixBot
      • Once in recovery mode, choose disk utility.
      • At the top left find the option to set the boot disk. This should be the new SSD that you just installed
      • I actually ran first aid on each partition before doing this step. I'm not sure if this was necessary.
      Ask FixBot
    6. How to prep and clone SSD with MacOS Catalina, Boot it UP!: step 9, image 1 of 1
      • Restart and it should boot like you never left.
      • Enter your password and login!
      • You can now use your old drive for a backup, time machine, or extra storage now that you have the adapter to use it!
      Ask FixBot
Enjoy the speeds of SSD!
lucas
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 29
All Time: 479
