Introduction
The drain valve in Jura machines is largely identical in design. If most of the coffee runs into the tray, the seals in the drain valve may be hardened, or the white cap on the valve tappet may be cracked. You will need a seal kit with two O-rings, as used on hoses, a special, slightly thinner O-ring for the docking connector, two or three lip seals depending on the model, and possibly the cap over the valve tappet. Here we show you how to replace the parts.
The brewing group has already been removed and disassembled. Now it's time for the drainage valve.
There will be many pictures
All you need a small flathead screwdriver.
When assembling, make sure that the lips of the seals point to the pressure side, i.e. inward, and the flat side outward.
When installing, make sure that the pressure hose runs through the slot in the valve carrier.
Apply a thin layer of food-safe silicone grease to the seals before installation.
Follow the steps in reverse order to reassemble your device.
Special thanks to these translators:
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
