Up to 20% off select tools
How to open the SteelSeries Nimbus+ Controller
Views: 2.5K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
90
All Time:
2,473
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to open the SteelSeries Nimbus+ controller for repairs and modding.
    1. How to open the SteelSeries Nimbus+ Controller, Remove the phone mount: step 1, image 1 of 2 How to open the SteelSeries Nimbus+ Controller, Remove the phone mount: step 1, image 2 of 2
      • Use your fingers to remove the phone mount by pulling it straight out of the controller.
      Ask FixBot
    2. How to open the SteelSeries Nimbus+ Controller, Remove the sticker: step 2, image 1 of 1
      • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
      • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
      Ask FixBot
    3. How to open the SteelSeries Nimbus+ Controller, Unscrew the back cover: step 3, image 1 of 1
      • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
      Ask FixBot
    4. How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: step 4, image 1 of 2 How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: step 4, image 2 of 2
      • The back cover is held in place by plastic clips.
      • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
      Ask FixBot
    5. How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: step 5, image 1 of 2 How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: step 5, image 2 of 2
      • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
      Ask FixBot
    6. How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: step 6, image 1 of 2 How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: step 6, image 2 of 2
      • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
      Ask FixBot
    7. How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: step 7, image 1 of 2 How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: step 7, image 2 of 2
      • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
      Ask FixBot
    8. How to open the SteelSeries Nimbus+ Controller, Unfold the back cover assembly: step 8, image 1 of 3 How to open the SteelSeries Nimbus+ Controller, Unfold the back cover assembly: step 8, image 2 of 3 How to open the SteelSeries Nimbus+ Controller, Unfold the back cover assembly: step 8, image 3 of 3
      • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
      • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
      Ask FixBot
    9. How to open the SteelSeries Nimbus+ Controller, Disconnect the battery cable: step 9, image 1 of 3 How to open the SteelSeries Nimbus+ Controller, Disconnect the battery cable: step 9, image 2 of 3 How to open the SteelSeries Nimbus+ Controller, Disconnect the battery cable: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
      Ask FixBot
    10. How to open the SteelSeries Nimbus+ Controller, Remove the back cover assembly: step 10, image 1 of 1
      • Remove the back cover assembly.
      Ask FixBot
Author
with
Adriana Zwink
69,952 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 90
All Time: 2,473
