How to open the Huawei Watch GT 2e
    1. How to open the Huawei Watch GT 2e, Turn off the watch: step 1, image 1 of 2 How to open the Huawei Watch GT 2e, Turn off the watch: step 1, image 2 of 2
      • Turn off the watch:
      • Press and hold the top button for >3 sec.
      • Tap "Power off".
      Ask FixBot
      • Push the small sliding nub on one of the watch band pins inwards toward the center of the watch band.
      • While holding the nub in, pull one side of the pin out of its recess on the watch housing, then the other side.
      • Remove the band.
      • Repeat this process to remove the second band.
      Ask FixBot
    2. How to open the Huawei Watch GT 2e, Remove the four rear screws: step 3, image 1 of 1
      • Remove the four 3.5 mm-long T3 Torx screws on the back of the watch.
      Ask FixBot
    3. How to open the Huawei Watch GT 2e, Open a small gap: step 4, image 1 of 3 How to open the Huawei Watch GT 2e, Open a small gap: step 4, image 2 of 3 How to open the Huawei Watch GT 2e, Open a small gap: step 4, image 3 of 3
      • Place the point of a spudger in the small hole on the side of the rear case.
      • Use the spudger to push the rear case away from the housing to create a small gap. Use steady force to separate the two parts.
      • Steady the rear case with a finger to avoid it suddenly popping open and damaging the flex cable.
      • Don’t open the rear case all the way just yet. It is still connected to the motherboard with a thin flex cable.
      Ask FixBot
    4. How to open the Huawei Watch GT 2e, Flip the rear case open: step 5, image 1 of 3 How to open the Huawei Watch GT 2e, Flip the rear case open: step 5, image 2 of 3 How to open the Huawei Watch GT 2e, Flip the rear case open: step 5, image 3 of 3
      • Flip the rear case assembly open towards the buttons to access the interconnect flex cable connector.
      Ask FixBot
    5. How to open the Huawei Watch GT 2e, Remove the bracket screw: step 6, image 1 of 1
      Tool used on this step:
      $3.99
      Buy
      • Remove the 2.5 mm-long Phillips screw securing the interconnect cable bracket.
      • When re-assembling you might need a pair of pointy angled tweezers to position the screw since they are non-ferrous and therefore don’t stick to the magnetic bit.
      Ask FixBot
    6. How to open the Huawei Watch GT 2e, Remove the bracket: step 7, image 1 of 3 How to open the Huawei Watch GT 2e, Remove the bracket: step 7, image 2 of 3 How to open the Huawei Watch GT 2e, Remove the bracket: step 7, image 3 of 3
      • Use a pair of tweezers to slide the interconnect cable bracket down and left to unlatch it.
      • Remove the interconnect cable bracket.
      • For reassembly make sure to slide the bracket into place from bottom left towards top right to engage the small latch.
      Ask FixBot
    7. How to open the Huawei Watch GT 2e, Unplug the flex cable: step 8, image 1 of 3 How to open the Huawei Watch GT 2e, Unplug the flex cable: step 8, image 2 of 3 How to open the Huawei Watch GT 2e, Unplug the flex cable: step 8, image 3 of 3
      • Use the flat end of a spudger to pry up and unplug the interconnect cable.
      • Remove the rear case assembly.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answer Community for help.
3 other people completed this guide.
Tobias Isakeit
134,958 Reputation
189 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 72
All Time: 4,211
