Up to 20% off select tools
How to open Logitech Z130 speakers
Views: 4.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
26
Past 30 Days:
144
All Time:
4,722
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 10 minutes
Difficulty: Easy
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
If you’re having trouble with your Logitech Z130 speakers, this guide will show you how to open them in order to access the internal components.
This guide isn’t intended for a specific repair, only to allow you to open the speakers to diagnose a problem.
    1. How to open Logitech Z130 speakers, Getting prepared: step 1, image 1 of 1
      • Warning: Unplug the device from power before you start!
      • Unplug the audio cable as well
      Ask FixBot
    2. How to open Logitech Z130 speakers, Remove the rear screws: step 2, image 1 of 1
      • At the rear of the speaker, remove two screws.
      Ask FixBot
    3. How to open Logitech Z130 speakers, Remove the front screws: step 3, image 1 of 2 How to open Logitech Z130 speakers, Remove the front screws: step 3, image 2 of 2
      • Two front screws are hidden by the speaker grid
      • Simply by pulling it, remove the speaker grid
      • Remove the two screws which are now apparent
      Ask FixBot
    4. How to open Logitech Z130 speakers, Remove the volume button and its nut: step 4, image 1 of 3 How to open Logitech Z130 speakers, Remove the volume button and its nut: step 4, image 2 of 3 How to open Logitech Z130 speakers, Remove the volume button and its nut: step 4, image 3 of 3
      • Remove the volume button by pulling it
      • Unscrew the nut which is now exposed
      • Remove the nut and the spacer
      Ask FixBot
    5. How to open Logitech Z130 speakers, Remove the bottom screws: step 5, image 1 of 2 How to open Logitech Z130 speakers, Remove the bottom screws: step 5, image 2 of 2
      • Two front screws are hidden by a pad below the speaker.
      • Remove the pad
      • Remove the two bottom screws.
      Ask FixBot
    6. How to open Logitech Z130 speakers, Open the speaker: step 6, image 1 of 1
      • Job's done, you are now able to open the speaker by gently pulling the front part of it.
      Ask FixBot
4 other people completed this guide.
Author
with
Benoit74
3,656 Reputation
11 Guides authored
3 Guide Comments
Thanks for this - I needed to open up my Z130 to spray contact cleaner in the volume potentiometer. No more breakup when turning the volume knob!
Jesse Smith - Reply Share
Whew! I was ruining the speaker plastic trying to pry this thing apart. Now I see I need to take out the two screws under the speaker grill!
Frank Zimmerman - Reply Share
Getting the speaker grill off was difficult - I had to insert a screwdriver and lever it upwards, bending the edge of the grill which later had to be straightened when I reassembled it.
Simon Kravis - Reply Share
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 144
All Time: 4,722
