This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Community-Contributed Guide
Introduction
Go to step 1 ↓Hello, today I am going to teach you how to make a TS (Tip Sleeve) jack, and for that we will need:
-a cable stripper
-solder
-a soldering iron
-wire strippers
-steel wool
To begin, you must strip the cable.
Then, insulate the braid located around the cable and twist the braid onto itself.
Then, strip the red conductor to expose the center conductor.
Tin the braid and the conductor.
Then, solder the center conductor to the Tip, which is the lowest part of the jack, and solder the braid to the Sleeve of the jack.
And there you have it, you have made a TS jack.
To reassemble your device, follow the instructions in reverse order.
