Up to 20% off select tools
How to install Windows 98 SE
Views: 1.5K
View statistics:
Past 24 Hours:
6
Past 7 Days:
64
Past 30 Days:
254
All Time:
1,505
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes - 1 hour
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide will walk you through the process of installing Windows 98 Second Edition.
Make sure the computer you are installing Win98 on has 1 GB of RAM or less.
      • At the first screen, choose "Boot from CD-ROM", then "Start Windows 98 Setup from CD-ROM"
      • Wait for Setup to initialize
      • When prompted, configure unallocated disk space and, if your drive is over 512MB, enable large disk support
      • Press ENTER to reboot.
      • Preform the same inputs as you did the first time and wait for Windows 98 to format the disk.
      Ask FixBot
      • Once you get to the Welcome screen, press Continue.
      • Wait for Setup to initialize.
      Ask FixBot
      • On the next screen, choose what you want the Windows directory to be. If you're unsure, leave it at the default C:\Windows.
      • Do not use special characters in the Windows directory path. Doing so may break some system components.
      • On the next screen, choose the components you want installed. If you want to customize per component, choose Custom.
      • On the next screen, enter your computer name, workgroup name, and a description for your computer. If you're unsure on any of these, leave them at their defaults.
      • Choose your region, click "Next", and wait for Windows 98 to reboot.
      Ask FixBot
      • If you still have the CD inserted, press "Boot from Hard Disk". Otherwise, Windows 98 should boot automatically.
      • Next, enter your name and your organization's name.
      • On the next screens, accept the EULA and enter your product key.
      • Lastly, press Finish and wait for Windows 98 to complete installation.
      • This stage can often have errors. If you encounter errors or if Setup freezes, rebooting may fix it.
      Ask FixBot
      • At the user login screen, enter your username and password. Since this is the first login, Windows 98 will have you confirm your password.
      • Explorer should load after this. If it doesn't, you may need to reinstall.
      Ask FixBot
Finish Line
Author
with
Sean-e
676 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 64
Past 30 Days: 254
All Time: 1,505
