How to install Windows 11 on unsupported devices
  1. How to install Windows 11 on unsupported devices, Install Rufus: step 1, image 1 of 2 How to install Windows 11 on unsupported devices, Install Rufus: step 1, image 2 of 2
    • Launch the windows command line interface.
    • Enter winget install Rufus.Rufus to install Rufus.
    • Restart the terminal application and launch Rufus by typing rufus.
    • If you are running a version of Windows older than Windows 10 1709 (build 16299) or it didn't work for any other reason, you'll need to manually download Rufus from the GitHub.
    Ask FixBot
  2. How to install Windows 11 on unsupported devices, Download the ISO: step 2, image 1 of 2 How to install Windows 11 on unsupported devices, Download the ISO: step 2, image 2 of 2
    Ask FixBot
  3. How to install Windows 11 on unsupported devices, Plug in the flash drive: step 3, image 1 of 1
    • Plug in a USB flash drive with a capacity of at least 8GB.
    • Any content on the flash drive will be deleted.
    Ask FixBot
  4. How to install Windows 11 on unsupported devices, Configure Rufus: step 4, image 1 of 3 How to install Windows 11 on unsupported devices, Configure Rufus: step 4, image 2 of 3 How to install Windows 11 on unsupported devices, Configure Rufus: step 4, image 3 of 3
    • Select the flash drive you want to use.
    • Select the ISO image you downloaded.
    • Press START.
    • Select the option Remove requirement for 4gb+ RAM, Secure Boot, and TPM 2.0 and confirm with OK.
    • Here you can also set other options, like to automatically opt out of data collection, or remove the requirement for a Microsoft account on setup.
    Ask FixBot
  5. How to install Windows 11 on unsupported devices, Boot from the flash drive: step 5, image 1 of 1
    • Boot from the USB flash drive by rebooting your PC while pressing the key that opens the boot-device selection menu.
    • This will vary from device to device, but typically Enter, Esc, F10 or F12 are a good starting point.
    • Select the option that boots the PC from the USB flash drive.
    • This will typically be called something along the lines of USB: Mass Storage.
    • Some devices, like the Microsoft Surface tablets, don’t use a menu and just directly boot from USB when p. ex. the Volume-Down button is pressed while turning the device on.
    Ask FixBot
  6. How to install Windows 11 on unsupported devices, Install Windows: step 6, image 1 of 1
    • Follow the instructions to install Windows.
    Ask FixBot
  7. How to install Windows 11 on unsupported devices, Finish: step 7, image 1 of 1
    • Remove the USB flash drive.
    • Remember to reset your boot priority if you had to change it on step 5.
    Ask FixBot
Have fun!
59 other people completed this guide.
Sebastian
33,352 Reputation
72 Guides authored
17 Guide Comments
Merci pour ce tuto. Windows 11 installé à partir de l'ISO téléchargée chez Microsoft fonctionnera-t-il indéfiniment ? Ou faut-il ensuite acheter une clé de validation ? Merci.
Rob - Reply Share
Les clés de validation de Windows sont liées à votre compte Microsoft ou à votre appareil. Si vous possédez déjà une clé Windows 10, elle devrait s'activer automatiquement. Si vous n'en avez pas et que vous êtes satisfait de ne pas personnaliser l'apparence de votre système, vous pouvez l'utiliser sans l'activer, car Microsoft est devenu moins strict en ce qui concerne l'obligation d'une clé. Cependant, un petit filigrane apparaîtra dans le coin de l'écran, vous demandant d'activer Windows à un moment donné.
Sebastian - Reply Share
Merci beaucoup pour ce tutoriel. Mais, je ne parviens pas à faire en sorte que ma clé USB soit bootable. En fait, la plupart des tutos, il est indiqué "Personnaliser l'installation de Windows" :
1. Supprimer la nécessité d'avoir 4 Go de RAM, Secure Boot et TPM 2.0
2. Supprimer la nécessité d'avoir un compte utilisateur Microsoft en ligne
Ce qui est surprenant, c'est que Rufus efface toutes les données de la clé USB, qui ne garde que l'icône de l'application Rufus. Lorsque Windows 11 est téléchargé sur la même clé USB, celle-ci n'est plus bootable.
Michel BERNARD - Reply Share
Est-ce une mise-à-jour ou bien une nouvelle install et faut-il sauvegarder le bureau pour retrouver tout ce qui se trouvait sur le bureau de W10 ? Merci
Pascal Vigeant - Reply Share
Very good tip, thx.
FrederPower - Reply Share
Past 24 Hours: 150
Past 7 Days: 1,081
Past 30 Days: 5,548
All Time: 288,682
