How to identify your iPhone
    1. How to identify your iPhone, iPhone 5: step 1, image 1 of 3 How to identify your iPhone, iPhone 5: step 1, image 2 of 3 How to identify your iPhone, iPhone 5: step 1, image 3 of 3
      • iPhone 5 has two parallel, horizontal screen connectors in the top right.. The larger, top one is the Digitizer connector, and the bottom, smaller one is the LCD connector. The vertical connection is used for camera and speaker functionality.
      Ask FixBot
    2. How to identify your iPhone, iPhone 5c: step 2, image 1 of 3 How to identify your iPhone, iPhone 5c: step 2, image 2 of 3 How to identify your iPhone, iPhone 5c: step 2, image 3 of 3
      • iPhone 5c has it's LCD and digitizer connectors in the top right. It has a horizontal digitizer connecter and a vertical LCD connecter to it's top left.
      Ask FixBot
    3. How to identify your iPhone, Difference between 5 and 5c: step 3, image 1 of 1
      • The main difference between the 5s and 5c is the 5s (left) is a thinner display than the 5c (right). The other smaller difference is that the digitizer connection is slightly larger.
      Ask FixBot
    4. How to identify your iPhone, iPhone 5s: step 4, image 1 of 3 How to identify your iPhone, iPhone 5s: step 4, image 2 of 3 How to identify your iPhone, iPhone 5s: step 4, image 3 of 3
      • The iPhone 5s has connectors that are similar to 5c where there is a horizontal LCD and a vertical digitizer.
      Ask FixBot
    5. How to identify your iPhone, Difference between the 5 and 5s: step 5, image 1 of 1
      • The iPhone 5 has two vertical connectors and the iPhone 5s has a horizontal and a vertical connector.
      Ask FixBot
    6. How to identify your iPhone, iPhone SE: step 6, image 1 of 2 How to identify your iPhone, iPhone SE: step 6, image 2 of 2
      • iPhone SE is very similar to iPhone 5s.
      • You can tell between the iPhone SE and iPhone 5s by checking the back of the phone.
      Ask FixBot
    7. How to identify your iPhone, iPhone 6: step 7, image 1 of 3 How to identify your iPhone, iPhone 6: step 7, image 2 of 3 How to identify your iPhone, iPhone 6: step 7, image 3 of 3
      • iPhone 6 has two parallel horizontal connectors in the top right. Following the same convention as the 5 series.
      Ask FixBot
    8. How to identify your iPhone, iPhone 6 Plus: step 8, image 1 of 3 How to identify your iPhone, iPhone 6 Plus: step 8, image 2 of 3 How to identify your iPhone, iPhone 6 Plus: step 8, image 3 of 3
      • The iPhone 6 Plus is very similar to the iPhone 6 except it's larger, and the connectors are longer.
      Ask FixBot
    9. How to identify your iPhone, iPhone 6s: step 9, image 1 of 3 How to identify your iPhone, iPhone 6s: step 9, image 2 of 3 How to identify your iPhone, iPhone 6s: step 9, image 3 of 3
      • The iPhone 6s has vertical and horizontal connectors as well as an identifying mark on the back of the phone designating it as an s
      Ask FixBot
    10. How to identify your iPhone, Difference between 6 and 6s: step 10, image 1 of 1
      • The main way to tell between the 6 and 6s is to check the back of the phone. If you don't already have it open.
      Ask FixBot
    11. How to identify your iPhone, iPhone 6s Plus: step 11, image 1 of 3 How to identify your iPhone, iPhone 6s Plus: step 11, image 2 of 3 How to identify your iPhone, iPhone 6s Plus: step 11, image 3 of 3
      • The iPhone 6s Plus is very similar to the 6s, except that the connectors are longer, and the screen is much larger.
      Ask FixBot
    12. How to identify your iPhone, iPhone 7: step 12, image 1 of 3 How to identify your iPhone, iPhone 7: step 12, image 2 of 3 How to identify your iPhone, iPhone 7: step 12, image 3 of 3
      • iPhone 7 has its connectors near the bottom right.
      Ask FixBot
    13. How to identify your iPhone, iPhone 7 Plus: step 13, image 1 of 3 How to identify your iPhone, iPhone 7 Plus: step 13, image 2 of 3 How to identify your iPhone, iPhone 7 Plus: step 13, image 3 of 3
      • iPhone 7 Plus is the same as the iPhone 7, except the screen and connectors are larger.
      Ask FixBot
    14. How to identify your iPhone, iPhone 8: step 14, image 1 of 3 How to identify your iPhone, iPhone 8: step 14, image 2 of 3 How to identify your iPhone, iPhone 8: step 14, image 3 of 3
      • iPhone 8 has its connectors in the same orientation as the iPhone 7 and are the same size.
      Ask FixBot
    15. How to identify your iPhone, iPhone 8 Plus: step 15, image 1 of 3 How to identify your iPhone, iPhone 8 Plus: step 15, image 2 of 3 How to identify your iPhone, iPhone 8 Plus: step 15, image 3 of 3
      • The iPhone 8 Plus is the same as the iPhone 8, except the screen and connectors are larger.
      Ask FixBot
    16. How to identify your iPhone, Main differences between iPhone 7 and iPhone 8: step 16, image 1 of 2 How to identify your iPhone, Main differences between iPhone 7 and iPhone 8: step 16, image 2 of 2
      • iPhone 7 and 8 are very similar except for the following differences:
      • The top brackets of the iPhone 7 are plastic and are metal for the iPhone 8. This makes changing screens considerably easier.
      • The back of the iPhone 7 is Aluminum whereas the back of the iPhone 8 is glass to facilitate wireless charging.
      Ask FixBot
    17. How to identify your iPhone, iPhone X: step 17, image 1 of 3 How to identify your iPhone, iPhone X: step 17, image 2 of 3 How to identify your iPhone, iPhone X: step 17, image 3 of 3
      • The iPhone X has two battery cells perpendicular to each other.
      Ask FixBot
    18. How to identify your iPhone, iPhone Xs: step 18, image 1 of 3 How to identify your iPhone, iPhone Xs: step 18, image 2 of 3 How to identify your iPhone, iPhone Xs: step 18, image 3 of 3
      • The iPhone XS has a gold square to the right of the camera bracket.
      Ask FixBot
    19. How to identify your iPhone: step 19, image 1 of 1
      • The iPhone X (Left) and Xs (Right) are extremely similar the only discernible way to tell the difference is to take a look at the back of the display. Look to the right of the camera bracket. The Xs will have a gold square and that is the only discernible difference.
      Ask FixBot
    20. How to identify your iPhone, iPhone XS Max: step 20, image 1 of 3 How to identify your iPhone, iPhone XS Max: step 20, image 2 of 3 How to identify your iPhone, iPhone XS Max: step 20, image 3 of 3
      • The Xs Max is just a larger version of the Xs just as the 11 pro has the 11 pro max.
      Ask FixBot
    21. How to identify your iPhone, iPhone XR: step 21, image 1 of 3 How to identify your iPhone, iPhone XR: step 21, image 2 of 3 How to identify your iPhone, iPhone XR: step 21, image 3 of 3
      • Insert wisdom here.
      Ask FixBot
    22. How to identify your iPhone, iPhone 11: step 22, image 1 of 3 How to identify your iPhone, iPhone 11: step 22, image 2 of 3 How to identify your iPhone, iPhone 11: step 22, image 3 of 3
      Ask FixBot
    23. How to identify your iPhone: step 23, image 1 of 1
      • The XR (Left) and 11 (Right) are extremely similar design the only real difference is that their cables are swapped. They are both the LCD version of that generation.
      Ask FixBot
    24. How to identify your iPhone, iPhone 11 Pro: step 24, image 1 of 3 How to identify your iPhone, iPhone 11 Pro: step 24, image 2 of 3 How to identify your iPhone, iPhone 11 Pro: step 24, image 3 of 3
      Ask FixBot
    25. How to identify your iPhone, iPhone 11 Pro Max: step 25, image 1 of 3 How to identify your iPhone, iPhone 11 Pro Max: step 25, image 2 of 3 How to identify your iPhone, iPhone 11 Pro Max: step 25, image 3 of 3
      Ask FixBot
    26. How to identify your iPhone, If your iPhone is Working: step 26, image 1 of 2 How to identify your iPhone, If your iPhone is Working: step 26, image 2 of 2
      • Open Settings.
      • Go to General.
      • Go to About.
      • The Model Number is listed as a part number. Tap it to display the "A" Model ID.
      Ask FixBot
Finish Line
4 other people completed this guide.
Karl Thaler
765 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 30
Past 30 Days: 160
All Time: 2,612
