How to flash MNT Reform keyboard firmware
    1. How to flash MNT Reform keyboard firmware, Unscrew the keyboard frame: step 1, image 1 of 1
      • Remove the following screws securing the keyboard frame to the main box:
      • Six black M2×5mm countersunk Philips screws
      Ask FixBot
    2. How to flash MNT Reform keyboard firmware, Remove the keyboard frame: step 2, image 1 of 1
      • Lift the top of the keyboard frame and pull it out towards the screen.
      • Your Reform should now look like this.
      • When re-assembling the Reform, insert the bottom of the keyboard frame into the main box before pressing it down. If the frame is not straight, very gently un-warp it, section by section with both hands close together.
      • Don't bend it with both hands on opposite ends of the frame — you'll likely twist it, especially the thinnest parts around the OLED display!
      Ask FixBot
    3. How to flash MNT Reform keyboard firmware, Set the SW84 switch to ON: step 3, image 1 of 1
      • Using a spudger or your fingernail, set the SW84 switch to ON.
      • The SW84 programming DIP switch is located near the F4 key of the keyboard, and to the left of the OLED display.
      Ask FixBot
      • Before you move on to the next step, you need to make sure you will be able to enter the ./flash.sh command without using the Reform's keyboard.
      • You have two options:
      • Connect an external USB keyboard.
      • Copy the ./flash.sh command followed by a new line in your text editor, so that you can paste it and run it without the use of a keyboard.
      • The script needs to be run as root, so make sure that you are using a root shell, or that sudo will not ask you to enter a password.
      Ask FixBot
    4. How to flash MNT Reform keyboard firmware, Press the SW83 button: step 5, image 1 of 1
      • Press the SW83 reset button, located right under the DIP switch from the previous step.
      Ask FixBot
    5. How to flash MNT Reform keyboard firmware, Flash the keyboard firmware: step 6, image 1 of 1
      • Run ./flash.sh as root.
      Ask FixBot
To reassemble your device, follow steps 1 and 2 in reverse order.
Neelfyn
981 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 69
All Time: 1,137
