How to fix stuck Joy-Con Triggers
    1. How to fix stuck Joy-Con Triggers, Removing Cover Screws: step 1, image 1 of 1
      • Using the Tri-Point Screwdriver, remove the 4 screws keeping the Joy-Con's shell together.
      Ask FixBot
    2. How to fix stuck Joy-Con Triggers, Opening the Joy-Con: step 2, image 1 of 1
      • Lift the shell to reveal the internals of the Joy-Con
      • If you are fixing the opposite-side Joy-Con, it will appear to be a mirror image
      Ask FixBot
    3. How to fix stuck Joy-Con Triggers, Locate the Button: step 3, image 1 of 1
      • Locate the ZR or ZL Button inside the Joy-Con Controller
      Ask FixBot
    4. How to fix stuck Joy-Con Triggers, Positioning the Button: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to lift the ZL button, then put it back into it's correct position
      • Put the button in a position where clicking is possible
      Ask FixBot
    5. How to fix stuck Joy-Con Triggers, Place the Shell back on the Joy-Con: step 5, image 1 of 1
      • Using the Tri-Point screwdriver, put the 4 screws back into place.
      Ask FixBot
Congratulations, you did it!
7 other people completed this guide.
Russell Repair Co.
2,337 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 54
Past 30 Days: 224
All Time: 13,263
