How to fix single buttons of a LED strip remote
    1. How to fix single buttons of a LED strip remote, Remove the front sticker: step 1, image 1 of 2 How to fix single buttons of a LED strip remote, Remove the front sticker: step 1, image 2 of 2
      • The white front of the remote is a sticker. Peel it off.
      • You can remove the battery and poke a pen or screwdriver through the hole to push the sticker up.
      Ask FixBot
    2. How to fix single buttons of a LED strip remote, Inspecting the buttons: step 2, image 1 of 1
      • The inside of the buttons has grey circles made from a conductive material. When pressed down, the grey conductive material connects two sides of a switch and lets the electricity flow.
      • The grey circles on the inside of the buttons that don't work might be worn off. If that is the case, this guide will help you fix them.
      Ask FixBot
    3. How to fix single buttons of a LED strip remote, Prepare conductor: step 3, image 1 of 2 How to fix single buttons of a LED strip remote, Prepare conductor: step 3, image 2 of 2
      • Color a corner of your sticky label in with pencil. It should be about as large as the grey circles inside the buttons.
      • Cut the penciled bit of label off.
      • Repeat as many times as you have buttons to fix.
      • Pencils are made from graphite, which conducts electricity.
      Ask FixBot
    4. How to fix single buttons of a LED strip remote, Place conductor: step 4, image 1 of 1
      • Stick your bit(s) of penciled label inside the broken button(s).
      • You can use scissors or tweezers for easier placement.
      Ask FixBot
Put the front sticker back onto the remote.
Re-insert the battery, if you removed it.
slowly_ly
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 64
All Time: 124
