How to fix an iPhone 4 home button
    1. How to fix an iPhone 4 home button, Home Button: step 1, image 1 of 3 How to fix an iPhone 4 home button, Home Button: step 1, image 2 of 3 How to fix an iPhone 4 home button, Home Button: step 1, image 3 of 3
      • Use the edge of an iPod opening tool or your fingernail to lift the home button ribbon cable retainer.
      • Be sure you are prying up on the cable retainer, not the socket itself.
      Ask FixBot
    2. How to fix an iPhone 4 home button: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers to pull the home button ribbon cable out of its socket.
      • Do not excessively strain the home button ribbon cable, as it is very thin and delicate. Also, be careful with the two small electronic parts on the ribbon cable. It is very easy to damage them with tweezers.
      Ask FixBot
    3. How to fix an iPhone 4 home button: step 3, image 1 of 1
      • De-route the home button ribbon cable through the inner case and remove the home button from the iPhone.
      • When installing a new part, there may be a protective plastic film on the home button. It can be removed with a spudger or your fingernail.
      Ask FixBot
    1. How to fix an iPhone 4 home button, How to fix an iPhone 4 home button: step 4, image 1 of 1
      • You need really thin blade to carefully peel off the plastic film from the back of the button. Do NOT touch the glue with your finger!
      Ask FixBot
    2. How to fix an iPhone 4 home button: step 5, image 1 of 3 How to fix an iPhone 4 home button: step 5, image 2 of 3 How to fix an iPhone 4 home button: step 5, image 3 of 3
      • After disassembly, you need some white spirit and cotton buds to clean up greenish oxide on both: button back contacts and steel cap's inside.
      • Last picture shows cleaned details.
      Ask FixBot
    3. How to fix an iPhone 4 home button: step 6, image 1 of 1
      • On reassembly, you have to position the steel cap in the center of copper contact ring, placing plastic sticker into its respective cavity on the back of the button.
      • Press the sticker firmly into its place. Don't worry if it doesnt stick all the way round. its position under the glass keeps the details in place. Again, try to prevent touching the glue while disassembling.
      • Congrats! Re-assemble your device and enjoy your revived home button!
      Ask FixBot
37 other people completed this guide.
Tarmo Palm
2,584 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 38
Past 30 Days: 154
All Time: 49,561
