How to fix Nintendo Switch Joy-Con_Drift
  1. How to fix Nintendo Switch Joy-Con_Drift, Before you start: step 1, image 1 of 1
    • Even if you don't touch the joystick, it will input directions.
    Ask FixBot
  2. How to fix Nintendo Switch Joy-Con_Drift, Ver1: step 2, image 1 of 1
    • Raise the metal claw next to the joystick. This part will break due to metal fatigue when trying to restore it.
    Ask FixBot
  3. How to fix Nintendo Switch Joy-Con_Drift, Ver1: step 3, image 1 of 1
    • The spring and white plastic parts come off when the back plate is removed.
    Ask FixBot
  4. How to fix Nintendo Switch Joy-Con_Drift, Ver1: step 4, image 1 of 2 How to fix Nintendo Switch Joy-Con_Drift, Ver1: step 4, image 2 of 2
    • Location of metal ring and white plastic parts
    Ask FixBot
  5. How to fix Nintendo Switch Joy-Con_Drift, Ver1: step 5, image 1 of 3 How to fix Nintendo Switch Joy-Con_Drift, Ver1: step 5, image 2 of 3 How to fix Nintendo Switch Joy-Con_Drift, Ver1: step 5, image 3 of 3
    • Clean the matte black areas with gloss with a cotton swab. *The change in the resistance value (black part) with the silver contact can be read with the position information.
    Ask FixBot
  6. How to fix Nintendo Switch Joy-Con_Drift, Ver1: step 6, image 1 of 1
    • Put the metal parts back in their original positions with the springs and white plastic parts, and attach them to Joy-con. (The metal nails in the picture broke when I tried to restore them.)
    Ask FixBot
  7. How to fix Nintendo Switch Joy-Con_Drift, Ver2: step 7, image 1 of 2 How to fix Nintendo Switch Joy-Con_Drift, Ver2: step 7, image 2 of 2
    • The metal press shape is different.
    Ask FixBot
  8. How to fix Nintendo Switch Joy-Con_Drift, Ver2: step 8, image 1 of 3 How to fix Nintendo Switch Joy-Con_Drift, Ver2: step 8, image 2 of 3 How to fix Nintendo Switch Joy-Con_Drift, Ver2: step 8, image 3 of 3
    • Use sharp-nose pliers and straighten the bent hinge part.
    Ask FixBot
  9. How to fix Nintendo Switch Joy-Con_Drift, Ver2: step 9, image 1 of 1
    • Use a precision screwdriver (minus) to remove it while raising the nail.
    • Remove without deforming, leaving the elasticity of the metal
    Ask FixBot
  10. How to fix Nintendo Switch Joy-Con_Drift, Ver2: step 10, image 1 of 1
    • Insert the screwdriver slowly and remove the metal frame. Be careful because there is a spring
    Ask FixBot
  11. How to fix Nintendo Switch Joy-Con_Drift, Ver2: step 11, image 1 of 1
    • Disassembled parts springs, metal washers, parts for push button, film substrate, metal frame
    • The metal frame is greased, so do not clean it here. (Wipe here to generate plastic powder.)
    • As expected, it may not be greased if it is not a genuine joystick. In that case, it is recommended to apply any grease.
    Ask FixBot
  12. How to fix Nintendo Switch Joy-Con_Drift, Ver2: step 12, image 1 of 3 How to fix Nintendo Switch Joy-Con_Drift, Ver2: step 12, image 2 of 3 How to fix Nintendo Switch Joy-Con_Drift, Ver2: step 12, image 3 of 3
    • The black part is a sensor that reads the resistance value. There is a line-like gloss here, so use a cotton swab to clean it.
    • CAUTION Wipe the metal terminals with a cotton swab dipped in alcohol. Be careful as it bends easily.
    Ask FixBot
  13. How to fix Nintendo Switch Joy-Con_Drift, Ver2: step 13, image 1 of 2 How to fix Nintendo Switch Joy-Con_Drift, Ver2: step 13, image 2 of 2
    • Attach the washer and push-button parts using tweezers.
    Ask FixBot
  14. How to fix Nintendo Switch Joy-Con_Drift, Ver2: step 14, image 1 of 1
    • Place the spring on the washer
    Ask FixBot
  15. How to fix Nintendo Switch Joy-Con_Drift, Ver2: step 15, image 1 of 1
    • Place the film substrate on the metal frame. Since there are two claws, please check the position and put it on.
    Ask FixBot
  16. How to fix Nintendo Switch Joy-Con_Drift, Ver2: step 16, image 1 of 1
    • The part using the radio pliers at the beginning cannot be removed without doing anything, so let's leave it as it is so that it can be easily removed when disassembling next.
    Ask FixBot
  17. How to fix Nintendo Switch Joy-Con_Drift: step 17, image 1 of 1
    • Since the metal frame is fixed with the plastic parts when returning it, it does not hinder the operation.
    • The photo is from Ver1
    Ask FixBot
  18. How to fix Nintendo Switch Joy-Con_Drift, Photo after work: step 18, image 1 of 1
    • The joystick is back in action!
    Ask FixBot
To reassemble your device, perform these steps in reverse order.
6 other people completed this guide.
Special thanks to these translators:
jp en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
syusan
558 Reputation
2 Guides authored
1 Guide Comment
Great Guide, works like a dream
lou reed - Reply Share
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 117
All Time: 8,861
