How to fix Huion Pen68 Dropped-drawing while hovering
Views: 19K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
112
All Time:
18,969
Comments: 19
2 comments on steps, 17 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 - 8 minutes
Difficulty: Difficult
Community-Contributed Guide
Introduction
Go to step 1 ↓
If you drop your huion pen and it starts drawing on its own while hovering, it could mean the inner was pushed in and the pen constantly on. This guide will help you adjust the inner as it supposed to be.
The Pen68 is the digital pen that comes with some of Huion's graphics tablets, including the Huion 420.
Tools
    1. How to fix Huion Pen68 Dropped-drawing while hovering, disassemble: step 1, image 1 of 3 How to fix Huion Pen68 Dropped-drawing while hovering, disassemble: step 1, image 2 of 3 How to fix Huion Pen68 Dropped-drawing while hovering, disassemble: step 1, image 3 of 3
      • Remove the buttons first. (use a flat screw driver or something similar) (pic 1)
      • Push the silver tab & black tab down and push upwards to remove the mainboard
      • twist the white cylinder to adjust the height offset of the nub
      • if you want to fully dissasemble desolder the two copper leads and fully unscrew the while cylinder
      Ask FixBot
    2. How to fix Huion Pen68 Dropped-drawing while hovering: step 2, image 1 of 3 How to fix Huion Pen68 Dropped-drawing while hovering: step 2, image 2 of 3 How to fix Huion Pen68 Dropped-drawing while hovering: step 2, image 3 of 3
      • Use a soldering iron to remove the wire (remember which one goes where.) (pic 1)
      • Mark the white plastic and the black one (so you know when to stop when screw it back) (pic 2)
      • Unscrew the white part. Just one or two turns to bring it back to the original position. If you would like to see what's inside, remember which way the spring goes when unscrew the whole thing. It's revrsed in this pic (pic 3)
      Ask FixBot
    3. How to fix Huion Pen68 Dropped-drawing while hovering, Reassemble: step 3, image 1 of 2 How to fix Huion Pen68 Dropped-drawing while hovering, Reassemble: step 3, image 2 of 2
      • Put everything back together. Stop the white plastic at the mark. Put the tip on to see if the spring works (the tip moves freely; turn the white plastic back or forth to get a design pressure sensitivity).
      • Remember to pull the metal up or else the pen won't have power. (pic 2)
      Ask FixBot
8 other people completed this guide.
thlong123
309 Reputation
1 Guide authored
17 Guide Comments
Man can I ask you something on google hangouts ? I couldn’t understand some points.
Peace Maker - Reply Share
I don't have hangout. Just ask here, I'll try to answer asap
thlong123 - Reply Share
Why we need soldering iron?
To use in step 2
I suspect this happened to mine but i dont have a soldering iron
Pixeled Forlife - Reply Share
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 112
All Time: 18,969
