How to fix Genie Intellicode Garage Remote Control battery issues
    1. How to fix Genie Intellicode Garage Remote Control battery issues, Acquire a battery holder: step 1, image 1 of 1
      • The battery is a 12 volt alkaline battery, part number 23A or A23 among others. Buy a matching battery holder. I got some from one of the numerous major online stores.
      Ask FixBot
    2. How to fix Genie Intellicode Garage Remote Control battery issues, Open the remote control: step 2, image 1 of 2 How to fix Genie Intellicode Garage Remote Control battery issues, Open the remote control: step 2, image 2 of 2
      • Remove metal clip (sorry, step not shown- just slide it up)
      • Using a philips screwdriver, remove the screw exposed by the metal clip.
      • The two plastic halves should mostly just separate.
      Ask FixBot
    3. How to fix Genie Intellicode Garage Remote Control battery issues, Cut ribs out of remote: step 3, image 1 of 3 How to fix Genie Intellicode Garage Remote Control battery issues, Cut ribs out of remote: step 3, image 2 of 3 How to fix Genie Intellicode Garage Remote Control battery issues, Cut ribs out of remote: step 3, image 3 of 3
      • The battery holder needs to fit inside the battery compartment, so remove some of the ribs molded in the plastic to hold the battery in the compartment and the battery door.
      • Use a hobby knife or side cutters to remove the ribs outlined in red.
      • Do not cut yourself. If you are not good with a hobby knife, there are other methods of removing the ribs such as a small rotary tool with a sanding drum, flush cutters, or even heat (again, be careful).
      Ask FixBot
    4. How to fix Genie Intellicode Garage Remote Control battery issues, Attach battery holder: step 4, image 1 of 1
      • First, figure which way the battery holder needs be inside the battery compartment. The red wire goes to the positive (+) terminal, and the black to the negative (-).
      • Desolder the battery tabs, cut down the wires on the battery holder (note that the black wire in the picture is just a bit short), and solder to PCB.
      Ask FixBot
    5. How to fix Genie Intellicode Garage Remote Control battery issues, Shave down battery holder: step 5, image 1 of 1
      • Cut down the lower back edge of the battery holder
      Ask FixBot
    6. How to fix Genie Intellicode Garage Remote Control battery issues, Test fit: step 6, image 1 of 2 How to fix Genie Intellicode Garage Remote Control battery issues, Test fit: step 6, image 2 of 2
      • Reassemble remote and see if the battery door closes completely. If it doesn't, shave down the plastics a bit more.
      • Once everything fits, screw it all back together, insert the battery, and test.
      Ask FixBot
Reinstall the metal clip and the remote is ready to go.
Mark H
758 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 87
All Time: 4,881
