How to enable charging past 90%
    1. How to enable charging past 90%, Attach the Battery Pack to the iPhone: step 1, image 1 of 2 How to enable charging past 90%, Attach the Battery Pack to the iPhone: step 1, image 2 of 2
      • Attach the MagSafe Battery Pack to the MagSafe location on the back of the iPhone.
      • The Apple logo on the MagSafe Battery Pack lines up with the Apple logo on your phone. This can help in positioning.
      • The LED indicator may glow green or amber depending upon the Battery Pack's charge condition.
      Ask FixBot
    2. How to enable charging past 90%, Indications of the Battery Pack: step 2, image 1 of 3 How to enable charging past 90%, Indications of the Battery Pack: step 2, image 2 of 3 How to enable charging past 90%, Indications of the Battery Pack: step 2, image 3 of 3
      • An onscreen toast will appear indicating the presence of the Battery Pack. The toast will indicate the following:
      • The charge level of the iPhone (icon and percentage).
      • The charge level of the Battery Pack (icon).
      • Indicate that the iPhone is accepting a charge.
      • Home screen widgets for Battery will indicate the charge level of the Battery Pack. The widget may also indicate if the Battery Pack is being charged (i.e. by cable, or by reverse charging).
      Ask FixBot
    1. How to enable charging past 90%, Add Low Power Mode to Control Center: step 3, image 1 of 2 How to enable charging past 90%, Add Low Power Mode to Control Center: step 3, image 2 of 2
      • Ensure that the Low Power Mode option is available in Control Center.
      • Enter Settings, Control Center. If "Low Power Mode" is not listed under "Included Controls," scroll down to "More Controls" and click the green plus sign to add it.
      • Verify it is now available under "Included Controls," and exit Settings.
      • For more information on editing the Control Center, see the Apple KB article.
      Ask FixBot
    2. How to enable charging past 90%, Enable 100% charging in the Low Power Mode control: step 4, image 1 of 2 How to enable charging past 90%, Enable 100% charging in the Low Power Mode control: step 4, image 2 of 2
      • Bring up the Control Center in iOS on your iPhone. (Method depends upon the model and iOS version. Generally, swipe down from the upper right corner.)
      • Locate the Low Power Mode button, and tap it.
      • Enable the "Charge past 90%" option now available with the MagSafe Battery Pack attached.
      • Tap the screen to dismiss the popup, then dismiss the Control Center.
      • For more information on Low Power Mode, see the Apple KB article.
      Ask FixBot
For more information on using the MagSafe Battery Pack, see the Apple KB article.
2 other people completed this guide.
David Spalding
6,635 Reputation
12 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 27
Past 30 Days: 88
All Time: 2,791
