How to dismount a Viessmann 7450156
    1. How to dismount a Viessmann 7450156, Shut off the Boiler: step 1, image 1 of 2 How to dismount a Viessmann 7450156, Shut off the Boiler: step 1, image 2 of 2
      • Locate the shutoff switch of your boiler and press it.
      • The switch is usually positioned right next to the flame-resistant door leading to the boiler room and labeled as Boiler Emergency Shutoff.
      Ask FixBot
    2. How to dismount a Viessmann 7450156, Locate the HMI module: step 2, image 1 of 1
      • Locate the HMI module of the Duomatik, that you want to remove.
      Ask FixBot
    3. How to dismount a Viessmann 7450156, Loosen the HMI module: step 3, image 1 of 2 How to dismount a Viessmann 7450156, Loosen the HMI module: step 3, image 2 of 2
      Tool used on this step:
      Spudger
      $3.99
      Buy
      • Insert a flathead screwdriver or a Spudger into the small notch on top of the module to gently loosen it.
      Ask FixBot
    4. How to dismount a Viessmann 7450156, Remove the HMI module: step 4, image 1 of 2 How to dismount a Viessmann 7450156, Remove the HMI module: step 4, image 2 of 2
      • Pull out the module straight toward yourself.
      Ask FixBot
Sebastian
33,535 Reputation
72 Guides authored
German Translators Member of German Translators
Community
51 Members
4,823 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 43
All Time: 877
