How to determine Mac shutdown causes
    1. How to determine Mac shutdown causes, Open Terminal.app: step 1, image 1 of 1
      • Open Terminal.app
      Ask FixBot
    2. How to determine Mac shutdown causes, Listing previous shutdowns: step 2, image 1 of 1
      • Copy and paste the following command in your Terminal window:
      • log show --predicate 'eventMessage contains "Previous shutdown cause"' --last 24h
      • The "24h" portion of the command can be changed to any number of hours, depending on how far back you need to see.
      Ask FixBot
    3. How to determine Mac shutdown causes, Determining Shutdown Causes: step 3, image 1 of 1
      • The previous shutdown causes in the timeframe you selected will appear as a list.
      • Common shutdown causes include 5 which indicates a normal shutdown, 3 which indicates a hard shutdown (i.e. holding the power button), and 0 which indicates the power was disconnected.
      • A list of shutdown causes can be found here: Shutdown causes (from George Garside blog)
      Ask FixBot
Done! You should be able to use these codes to further troubleshoot random shutdowns or other strange events.
Hit the button below if this guide helped solve your issue :)
24 other people completed this guide.
Attached Documents
Jonah Aragon
5,746 Reputation
5 Guides authored
Experimax Coon Rapids Member of Experimax Coon Rapids
Business
3 Members
60 Guides authored
14 Guide Comments
For me it says
kernel: (AppleSMC) Previous shutdown cause: -20
The attached PDF (and the internet) doesn’t seem to have any information about this code. What’s the source of the codes for the PDF? Maybe they have updated listing for shutdown codes.
Saurabh Shrivastava - Reply Share
we also have -20 as a cause and have no idea what it means. did you ever find it out?
octomobiki - Reply Share
I also have -20 code of shut down after macOS 10.15.5 update with MBP 16inches model.
but no information at all….
赤月小黄泉 - Reply Share
writErr = -20, /*I/O System Errors*/ its this error for code -20 .. Find all error codes here :- https://krypted.com/lists/comprehensive-...
UNKNOWN X - Reply Share
Sorry , that was not related, check this one : - https://georgegarside.com/blog/macos/shu...
and, error code 20- T2 security chip initiated shutdown
Past 24 Hours: 11
Past 7 Days: 110
Past 30 Days: 441
All Time: 108,545
