How to create and install a Cisco EX90 console cable
  1. How to create and install a Cisco EX90 console cable, How to create and install a Cisco EX90 console cable: step 1, image 1 of 1
    • Gather the necessary tools
    • 1--Soldering Iron
    • 2--Solder
    • 3--DB9 Enclosure. This one is being used here.
    • 4--RS232 to TTL/CMOS converter. alldav.com sells the one used here. Cisco does not recommend or endorse Alldav specifically.
    • 5--Cable w/RJ45 connector on one end Any type of cable with an 8P8C (RJ45) connector could used as long as pins 1,2,7 & 8 are connected. A standard RJ45 cable is being used here.
    • You will also need wire strippers and possibly a screwdriver (depending on which DB9 enclosure you are using).
    Ask FixBot
  2. How to create and install a Cisco EX90 console cable: step 2, image 1 of 1
    • Prep the cable. Strip the sheathing from the wires that correspond to pins 1,2,7 & 8.
    Ask FixBot
  3. How to create and install a Cisco EX90 console cable: step 3, image 1 of 1
    • Connect the RS232 to TTL/CMOS converter. Connect the RS232 to TTL/CMOS converter to the cable and solder the connections. Note: The colors used in the wiring diagram don't correspond to the color of the actual wires.
    Ask FixBot
  4. How to create and install a Cisco EX90 console cable: step 4, image 1 of 1
    • Install the Enclosure The EX90 console is now complete. The subsequent steps will cover making a console connection.
    Ask FixBot
  5. How to create and install a Cisco EX90 console cable: step 5, image 1 of 1
    • Make a Console Connection. Locate the Console Port. The EX90 console port is an 8P8C (RJ45) connection and is located on the bottom left corner of the unit.
    Ask FixBot
  6. How to create and install a Cisco EX90 console cable: step 6, image 1 of 1
    • Connect to the Console Port. Plug the 8P8C (RJ45) end into the console port. You'll have to lean the unit forward to plug the cable in. It might be a little awkward to do alone. If someone else is available, ask for their assistance. As a last resort, lay the unit down. Ensure you have something soft (like a towel) to lay the unit on.
    Ask FixBot
  7. How to create and install a Cisco EX90 console cable: step 7, image 1 of 1
    • Connect the DB9 to a USB serial adapter and connect to a laptop/PC.
    Ask FixBot
  8. How to create and install a Cisco EX90 console cable: step 8, image 1 of 1
    • Configure a Terminal Emulator Session Configure your terminal emulator with the following parameters:
    • Baud=38400
    • Data bits=8
    • Parity=none
    • Stop bits=1
    • Flow Control=none
    • The example uses HyperTerminal for Windows; configuring your terminal emulator may vary slightly.
    • You should now be at a login prompt when you connect with the terminal emulator.
    Ask FixBot
Finish Line
2 other people completed this guide.
eric
241 Reputation
1 Guide authored
1 Guide Comment
Thanks for this Amazing Blog. It is very informative and helpful for me.
<a href="http://pdfdumps.us/exam/220-801.html">Pass4sure 220-801 dumps</a>
ademarr - Reply Share
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 59
All Time: 8,569
