How to clear Lexmark Intuition S505 paper jam
  1. How to clear Lexmark Intuition S505 paper jam, How to clear Lexmark Intuition S505 paper jam: step 1, image 1 of 2 How to clear Lexmark Intuition S505 paper jam, How to clear Lexmark Intuition S505 paper jam: step 1, image 2 of 2
    • Lift the scanning unit.
    Ask FixBot
  2. How to clear Lexmark Intuition S505 paper jam: step 2, image 1 of 2 How to clear Lexmark Intuition S505 paper jam: step 2, image 2 of 2
    • Check the duplex unit, located at the rear of the printer, for any paper obstruction. Pinch the top button to remove the unit.
    Ask FixBot
  3. How to clear Lexmark Intuition S505 paper jam: step 3, image 1 of 1
    • If there is any paper stuck inside, remove it. If not, snap the unit back onto the printer.
    Ask FixBot
  4. How to clear Lexmark Intuition S505 paper jam: step 4, image 1 of 1
    • Check the front slot, which is located underneath the LED display. If there is any paper, remove it.
    Ask FixBot
Once the paper obstruction is removed, your printer should print smoothly without any problems.
2 other people completed this guide.
Omar
132 Reputation
2 Guides authored
Cal Poly, Team 18-38, Regan Winter 2013 Member of Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
4 Members
8 Guides authored
1 Guide Comment
Mine still says paper jam but there's no paper stuck in it all. Can you suggest other probs and solutions?
Debra Collis (Debbie) - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 38
All Time: 2,132
