How to clean the Apple Magic Mouse 2
    1. How to clean the Apple Magic Mouse 2, Wipe Down the Mouse: step 1, image 1 of 2 How to clean the Apple Magic Mouse 2, Wipe Down the Mouse: step 1, image 2 of 2
      Tool used on this step:
      Microfiber Cleaning Cloths
      $3.99
      Buy
      • Using a soft or microfiber cloth, rub on the glass, laser sensor, and the metal portion of the mouse to remove any dust or smudges.
      • After doing a dry wipe off the outside of the mouse, it is recommended to use isopropyl alcohol to sanitize the mouse. Water can be used as a cleaning alternative too.
      • Make sure to apply the alcohol or water to the cloth and use small amounts when cleaning to ensure the internals of the mouse stay dry.
      Ask FixBot
    2. How to clean the Apple Magic Mouse 2, Cleaning the bottom part of the Mouse: step 2, image 1 of 2 How to clean the Apple Magic Mouse 2, Cleaning the bottom part of the Mouse: step 2, image 2 of 2
      • Dirt and debris can build up in the charging port and in between the rubber and the mouse. Constant cleaning can ensure the mouse stays clean and functions well.
      • Using your spudger tool, carefully move the spudger in the grooves of the mouse and rubber. This will help to remove and loosen any debris.
      • Using the flat edge of the spudger, carefully move it around the lightning port to loosen any debris.
      • It is recommended to use canned air to remove any debris from the port, otherwise you can lightly shake the port to remove any loosened debris.
      • Be careful when cleaning the lightning port as there is a risk of damaging the port itself.
      Ask FixBot
Finish Line
7 other people completed this guide.
Colton Turner
588 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 34
Past 30 Days: 156
All Time: 12,545
