How to clean Canon PowerShot A550 buttons
  1. How to clean Canon PowerShot A550 buttons, Front and Back Covers: step 1, image 1 of 3 How to clean Canon PowerShot A550 buttons, Front and Back Covers: step 1, image 2 of 3 How to clean Canon PowerShot A550 buttons, Front and Back Covers: step 1, image 3 of 3
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
    Ask FixBot
  2. How to clean Canon PowerShot A550 buttons: step 2, image 1 of 1
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
    Ask FixBot
  3. How to clean Canon PowerShot A550 buttons: step 3, image 1 of 1
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
    Ask FixBot
  4. How to clean Canon PowerShot A550 buttons: step 4, image 1 of 2 How to clean Canon PowerShot A550 buttons: step 4, image 2 of 2
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
    Ask FixBot
  5. How to clean Canon PowerShot A550 buttons: step 5, image 1 of 1
    • The camera should look like this once the front cover is removed.
    Ask FixBot
  6. How to clean Canon PowerShot A550 buttons: step 6, image 1 of 3 How to clean Canon PowerShot A550 buttons: step 6, image 2 of 3 How to clean Canon PowerShot A550 buttons: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
    Ask FixBot
  7. How to clean Canon PowerShot A550 buttons: step 7, image 1 of 1
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
    Ask FixBot
  8. How to clean Canon PowerShot A550 buttons, How to clean Canon PowerShot A550 buttons: step 8, image 1 of 1
    • Turn to the back of the camera body. Rub the function keys and surrounding area with a clean cloth dipped in isopropyl alcohol.
    Ask FixBot
2 other people completed this guide.
Shaelyn Thomas
392 Reputation
4 Guides authored
Cal Poly, Team 8-6, Regan Spring 2011 Member of Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
4 Members
22 Guides authored
1 Guide Comment
new Battery in side & massages is Battery low why?
Rupesh Jamsandekar - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 37
All Time: 2,467
