How to change the keyboard layout using Kali Linux Terminal
Views: 161K
View statistics:
Past 24 Hours:
29
Past 7 Days:
123
Past 30 Days:
475
All Time:
161,164
Comments: 7
7 guide comments.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Easy
Community-Contributed Guide
      • Press Ctrl + Alt + T to open the Terminal Interface.
      Ask FixBot
      • Enter the following code: sudo dpkg-reconfigure keyboard-configuration
      • The configuring keyboard-configuration selection screen will pop up with different keyboard models. Use the arrow-keys to select the layout of your choice and press Enter to make your selection.
      • If you're outside the US scroll down to the bottom and select Other
      Ask FixBot
      • Once your keyboard model is selected choose the default option for your keyboard layout and press Enter.
      • Once complete you can add a compose key, but this is optional. Hit Enter to exit the GUI.
      Ask FixBot
      • To complete the process enter the command: sudo service keyboard-setup restart
      Ask FixBot
While this process is slightly more complex than the GUI method of changing the layout, this process is much quicker than the GUI method.
11 other people completed this guide.
Jacob Mehnert
50,133 Reputation
52 Guides authored
iFanatics Member of iFanatics
Community
70 Members
1,152 Guides authored
7 Guide Comments
buonasera, sono un neofita di linux che ho trovato sbalorditivo, l'ho installato su un pc lenovo che ormai stavo per rottamare perchè andava lentissimo ed ora con linux funziona alla grande. Ad oggi ho un'unico problema, non riesco a digitare con la tastiera i caratteri che si ottengono con la combinazione crlt+alt+(es. @), il pc è un lenovo G50 del 2014, seguendo la procedura che avete indicato non ho trovato la tastiera per questo modello, come posso fare per associare la tastiera corretta? grazie in anticipo per la risposta!
saluti
Paolo
paolo - Reply Share
Ciao, puoi anche cambiare il layout della tastiera usando il layout della GUI di Kali Linux. Se fai clic su "Impostazioni" > "Hardware" > "Tastiera", dovrebbe essere disponibile un'opzione per LayoutCiao, puoi anche cambiare il layout della tastiera usando il layout della GUI di Kali Linux. Se fai clic su "Impostazioni" > "Hardware" > "Tastiera", dovrebbe essere disponibile un'opzione per Layout
Jacob Mehnert - Reply Share
ciao, perdona se rompo le scatole, la tastiera rilevata è quella italiana, ho provato anche italian windows, ma il problema persiste, la combinazione tasti crtl+alt+simbolo non fornisce alcun effetto
paolo - Reply Share
se provo ad inserire A user-defined custom layout mi da un errore di configurazione XKB
paolo - Reply Share
ho istalllato linux kali con drop box sull mio mac ios ma no
n riesco a scrivere. il meno mi inserisce lo slash
luca - Reply Share
Past 24 Hours: 29
Past 7 Days: 123
Past 30 Days: 475
All Time: 161,164
